The two dash lines on the Ducati flywheel are 1) TDC and 2) 22mm advance right? Checked with a dial then with timing light and TDC is at the first dash line coincidentally lining up with the triangular mark on the case. Then I rotated the stator counter clockwise all the way. Now the little triangle on the case lines up with the second dash line on the flywheel. Is it as easy as that? Anyway, the Polini manual calls to advance timing to 22mm and mentions the markings on the flywheel.
