Re: Popping at WOT (video attached)
🇮🇹💦 Of the Loin /
I've definitely experienced this with that rural Midwest gasoline
I don't remember degrees or numbers of timing in V1s because the stock timing works pretty good for everything (not great, but pretty good!)
Do the timing mark on the flywheel and the timing mark on the case line up?
Holding 3/4 OR WOT causing this points to it not likely to be a jetting issue.
I'd clean your grounds and replace your taillight bulb
