Re: Puch E50 w pietcard 3055 and 2041 cdi
Justabunchoftrash 646260 /
> Jeff Parr Wrote:
> What I have found. You have slot the hell out of adjustment slots
> only slot the ones marked yes, the marked no is of no use and no bolt
> will be in it. slot in the direction marked. be sure to set the RPM to
> the manual spec and you will be good. I have the timing set at 17*
> checked a timing light and I still have the woodruff key in place.
Woodroof keys and sloting your strator is totally last year. Ditch the key find the firing mark, leave your strator alone & Mount it with the slots in the middle position so you can add or take timing out. No butchering and you have all the slotting the play with.
That’s how hpi basically made their ignition, you think the Cheaper cdi Kits would atleast come with a firing mark on the strator and magneto ( maybe they thought if a different cdi was substituted in the kit it would mess every up)
I can mount a cdi upside down its just understand ignition timing to Piston position...simple really (edited)
  Puch E50 w pietcard 3055 and 2041 cdiTopic by: Jeff Parr Jeff Parr 05/11/20 01:58PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: Jay Rivett Jay Rivett 05/11/20 02:06PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: P D P D 05/11/20 04:00PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: James P James P 05/11/20 04:18PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: P D P D 05/11/20 04:31PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: James P James P 05/11/20 04:46PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: Justabunchoftrash 646260 Justabunchoftrash 646260 05/11/20 04:49PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: Jay Rivett Jay Rivett 05/11/20 05:09PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: Justabunchoftrash 646260 Justabunchoftrash 646260 05/11/20 05:26PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: P D P D 05/11/20 06:01PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: James P James P 05/11/20 06:09PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: Jeff Parr Jeff Parr 05/11/20 06:27PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: Jay Rivett Jay Rivett 05/11/20 09:23PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: Jeff Parr Jeff Parr 05/11/20 10:54PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: Jeff Parr Jeff Parr 05/14/20 07:59PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: P D P D 05/14/20 08:52PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: Jeff Parr Jeff Parr 05/14/20 11:41PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: Mike Boyd Mike Boyd 05/15/20 01:34AM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: P D P D 05/15/20 10:53AM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: Justabunchoftrash 646260 Justabunchoftrash 646260 05/15/20 12:49AM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: Graham Motzing Graham Motzing 05/15/20 12:49PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: Kevin Bishop Kevin Bishop 05/17/20 08:01PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: Mike Boyd Mike Boyd 05/19/20 12:41PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: Kevin Bishop Kevin Bishop 05/17/20 08:03PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: Jeff Parr Jeff Parr 05/18/20 10:46AM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: Kevin Bishop Kevin Bishop 05/19/20 10:34AM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: Kevin Bishop Kevin Bishop 05/19/20 11:10AM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: Kevin Bishop Kevin Bishop 05/19/20 12:56PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: Mike Boyd Mike Boyd 05/19/20 02:12PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: Jeff Parr Jeff Parr 05/19/20 01:09PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: Jeff Parr Jeff Parr 05/19/20 02:33PM
