Re: Puch E50 w pietcard 3055 and 2041 cdi
Jay Rivett /
Both this or the previous posts involve repositioning the flywheel to a place that is not keyed. Ok, but I guess I dont get the sand paper bit on the flywheel.... is this so that it stays in place better? And am I sanding the flywheel some place or adhering the paper to the flywheel? Is there any tutorials on this process?
Thanks for all the info!
> Barack Obama Wrote:
> Guys seriously!
> Forgot about everything and focus on one thing & that is your firing
> mark!
> Use a drill, sharpie & timing light!
> Make a line on the case near the flywheel rim and Put a bunch of lines
> on the flywheel randomly and number them.Spin the flywheel with the
> drill While using the timing light, find a number that is close to The
> light flashIng , remove all Other the lines and numbers with alcohol.
> now put a bunch of lines Very close to the line You kept & number them.
> Using the drill and timing light and should find that one of these lines
> matches up perfect with your Case line! This is your firing mark, it
> will never change so take a nail & make a permanent line with the letter
> f on your flywheel.
> now using a piston degree tool find 14 degrees, push the piston right up
> against the tool ( compression stroke) and install the flywheel with
> the case line and firing line matching up.
> If you don’t have a degree tool you can actually just use the flywheel
> with paper measuring tape and a long plug.
> You’ll have to spin the flywheel pretty fast with the drill with a cdi
> to get the timing light to kick on
  Puch E50 w pietcard 3055 and 2041 cdiTopic by: Jeff Parr Jeff Parr 05/11/20 01:58PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: Jay Rivett Jay Rivett 05/11/20 02:06PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: P D P D 05/11/20 04:00PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: James P James P 05/11/20 04:18PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: P D P D 05/11/20 04:31PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: James P James P 05/11/20 04:46PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: Justabunchoftrash 646260 Justabunchoftrash 646260 05/11/20 04:49PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: Jay Rivett Jay Rivett 05/11/20 05:09PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: Justabunchoftrash 646260 Justabunchoftrash 646260 05/11/20 05:26PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: P D P D 05/11/20 06:01PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: James P James P 05/11/20 06:09PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: Jeff Parr Jeff Parr 05/11/20 06:27PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: Jay Rivett Jay Rivett 05/11/20 09:23PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: Jeff Parr Jeff Parr 05/11/20 10:54PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: Jeff Parr Jeff Parr 05/14/20 07:59PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: P D P D 05/14/20 08:52PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: Jeff Parr Jeff Parr 05/14/20 11:41PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: Mike Boyd Mike Boyd 05/15/20 01:34AM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: P D P D 05/15/20 10:53AM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: Justabunchoftrash 646260 Justabunchoftrash 646260 05/15/20 12:49AM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: Graham Motzing Graham Motzing 05/15/20 12:49PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: Kevin Bishop Kevin Bishop 05/17/20 08:01PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: Mike Boyd Mike Boyd 05/19/20 12:41PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: Kevin Bishop Kevin Bishop 05/17/20 08:03PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: Jeff Parr Jeff Parr 05/18/20 10:46AM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: Kevin Bishop Kevin Bishop 05/19/20 10:34AM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: Kevin Bishop Kevin Bishop 05/19/20 11:10AM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: Kevin Bishop Kevin Bishop 05/19/20 12:56PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: Mike Boyd Mike Boyd 05/19/20 02:12PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: Jeff Parr Jeff Parr 05/19/20 01:09PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: Jeff Parr Jeff Parr 05/19/20 02:33PM
