Re: Puch E50 w pietcard 3055 and 2041 cdi
Justabunchoftrash 646260 /
Guys seriously!
Forgot about everything and focus on one thing & that is your firing mark!
Use a drill, sharpie & timing light!
Make a line on the case near the flywheel rim and Put a bunch of lines on the flywheel randomly and number them.Spin the flywheel with the drill While using the timing light, find a number that is close to The light flashIng , remove all Other the lines and numbers with alcohol. now put a bunch of lines Very close to the line You kept & number them. Using the drill and timing light and should find that one of these lines matches up perfect with your Case line! This is your firing mark, it will never change so take a nail & make a permanent line with the letter f on your flywheel.
now using a piston degree tool find 14 degrees, push the piston right up against the tool ( compression stroke) and install the flywheel with the case line and firing line matching up.
If you don’t have a degree tool you can actually just use the flywheel with paper measuring tape and a long plug.
You’ll have to spin the flywheel pretty fast with the drill with a cdi to get the timing light to kick on (edited)
  Puch E50 w pietcard 3055 and 2041 cdiTopic by: Jeff Parr Jeff Parr 05/11/20 01:58PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: Jay Rivett Jay Rivett 05/11/20 02:06PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: P D P D 05/11/20 04:00PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: James P James P 05/11/20 04:18PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: P D P D 05/11/20 04:31PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: James P James P 05/11/20 04:46PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: Justabunchoftrash 646260 Justabunchoftrash 646260 05/11/20 04:49PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: Jay Rivett Jay Rivett 05/11/20 05:09PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: Justabunchoftrash 646260 Justabunchoftrash 646260 05/11/20 05:26PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: P D P D 05/11/20 06:01PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: James P James P 05/11/20 06:09PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: Jeff Parr Jeff Parr 05/11/20 06:27PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: Jay Rivett Jay Rivett 05/11/20 09:23PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: Jeff Parr Jeff Parr 05/11/20 10:54PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: Jeff Parr Jeff Parr 05/14/20 07:59PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: P D P D 05/14/20 08:52PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: Jeff Parr Jeff Parr 05/14/20 11:41PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: Mike Boyd Mike Boyd 05/15/20 01:34AM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: P D P D 05/15/20 10:53AM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: Justabunchoftrash 646260 Justabunchoftrash 646260 05/15/20 12:49AM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: Graham Motzing Graham Motzing 05/15/20 12:49PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: Kevin Bishop Kevin Bishop 05/17/20 08:01PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: Mike Boyd Mike Boyd 05/19/20 12:41PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: Kevin Bishop Kevin Bishop 05/17/20 08:03PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: Jeff Parr Jeff Parr 05/18/20 10:46AM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: Kevin Bishop Kevin Bishop 05/19/20 10:34AM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: Kevin Bishop Kevin Bishop 05/19/20 11:10AM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: Kevin Bishop Kevin Bishop 05/19/20 12:56PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: Mike Boyd Mike Boyd 05/19/20 02:12PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: Jeff Parr Jeff Parr 05/19/20 01:09PM
  Re: Puch E50 w pietcard 3055 and 2041 cdiRe: Jeff Parr Jeff Parr 05/19/20 02:33PM
