Re: Custom intake advantage
JBOT Admin /
Changing your intake without doing anything else isnt going to do much of anything.
That being said, I make intakes for every bike, usually use carbs at 19mm or bigger and use all sorts of tubing/bicycle forks/handlebars etc for the main tube, then weld it to a thick washer cut and drilled as the flange.
