DIY Case boring for large kits
First, determine the desired bore size. Find a hole saw thats as close as possible in OD to the cylinder skirt of your new kit.
Then, find a hole saw that has an ID thats the same as the ID of your cases. Use that hole saw to drill out a plug that will fit snugly into the cases to support the pilot bit of the hole saw. Use the hardest wood or plastic you can get to help the pilot hole last longer, this will help everything get started more smoothly.
Pop your plug into the cases. Then, take your hole saw that's the OD of your skirts and get drilling. You can do this with a hand drill, but a drill press would make things more foolproof.
Use high quality hole saws if you can, they will run much more true and will help things go smoothly.
  DIY Case boring for large kitsTopic by: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 05/10/20 02:14PM
  Re: DIY Case boring for large kitsRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 05/10/20 02:15PM
  Re: DIY Case boring for large kitsRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 05/10/20 02:19PM
  Re: DIY Case boring for large kitsRe: Rich Condor Rich Condor 05/10/20 03:01PM
  Re: DIY Case boring for large kitsRe: Dirty30 Dillon Dirty30 Dillon 05/10/20 03:36PM
  Re: DIY Case boring for large kitsRe: kenny s kenny s 05/10/20 06:09PM
  Re: DIY Case boring for large kitsRe: Dirty30 Dillon Dirty30 Dillon 05/10/20 09:32PM
  Re: DIY Case boring for large kitsRe: pat splat pat splat 05/10/20 10:19PM
  Re: DIY Case boring for large kitsRe: Jay Rivett Jay Rivett 05/11/20 02:10PM
  Re: DIY Case boring for large kitsRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 05/11/20 03:57PM
  Re: DIY Case boring for large kitsRe: Graham Motzing Graham Motzing 05/15/20 12:54PM
  Re: DIY Case boring for large kitsRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 05/15/20 01:18PM
  Re: DIY Case boring for large kitsRe: Joel P Joel P 05/14/20 02:06AM
  Re: DIY Case boring for large kitsRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 05/14/20 12:03PM
  Re: DIY Case boring for large kitsRe: alex . alex . 05/11/20 03:12PM
  Re: DIY Case boring for large kitsRe: Denis Kozlowski Denis Kozlowski 05/11/20 05:10PM
  Re: DIY Case boring for large kitsRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 05/11/20 06:32PM
  Re: DIY Case boring for large kitsRe: Denis Kozlowski Denis Kozlowski 05/11/20 08:00PM
  Re: DIY Case boring for large kitsRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 05/11/20 10:39PM
  Re: DIY Case boring for large kitsRe: Jay Rivett Jay Rivett 05/12/20 08:21AM
  Re: DIY Case boring for large kitsRe: Ben Whittle Ben Whittle 05/12/20 10:58AM
  Re: DIY Case boring for large kitsRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 05/12/20 12:57PM
  Re: DIY Case boring for large kitsRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 05/12/20 01:03PM
  Re: DIY Case boring for large kitsRe: P D P D 05/12/20 03:31PM
  Re: DIY Case boring for large kitsRe: Dave & Bummerzz Dave & Bummerzz 05/12/20 09:05AM
  Re: DIY Case boring for large kitsRe: Dirty30 Dillon Dirty30 Dillon 05/12/20 09:29AM
  Re: DIY Case boring for large kitsRe: Blake Totally a real doctor Blake Totally a real doctor 05/12/20 11:42AM
  Re: DIY Case boring for large kitsRe: Dave & Bummerzz Dave & Bummerzz 05/12/20 11:55AM
  Re: DIY Case boring for large kitsRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 05/12/20 11:48AM
  Re: DIY Case boring for large kitsRe: Kevin Bishop Kevin Bishop 05/17/20 07:03PM
  Re: DIY Case boring for large kitsRe: Joel P Joel P 05/17/20 07:37PM
  Re: DIY Case boring for large kitsRe: Kevin Bishop Kevin Bishop 05/17/20 08:09PM
