DIY Case boring for large kits
First, determine the desired bore size. Find a hole saw thats as close as possible in OD to the cylinder skirt of your new kit.
Then, find a hole saw that has an ID thats the same as the ID of your cases. Use that hole saw to drill out a plug that will fit snugly into the cases to support the pilot bit of the hole saw. Use the hardest wood or plastic you can get to help the pilot hole last longer, this will help everything get started more smoothly.
Pop your plug into the cases. Then, take your hole saw that's the OD of your skirts and get drilling. You can do this with a hand drill, but a drill press would make things more foolproof.
Use high quality hole saws if you can, they will run much more true and will help things go smoothly.
Re: DIY Case boring for large kits
As you can see, it started a bit rough, and I got a little close to the stud holes. I ended up adding just a little material with alumiweld, and it will seal just fine. Went way faster than the drum sander method, and once you get it started it goes very quickly. Actual drilling time was just 2-3 minutes with stops included to clear chips and add lube. I'll still need to go in there with the dremel and carbides to clean up.
Bravo Sir!
Not exactly what I expected I wonder how much a machine shop would charge for this ? Versus your pricing structure
Dirty30 Dillon /
Excellent work and good innovative application.
Standard hole saws are HSS tips so they def chew through alu pretty fast.
The weird thing about one of my engines is th the case was already bored. The sprocket was already bigger but it still had restrictions.
Dirty30 Dillon /
Having a larger bore has nothing to do with sprocket size or restrictions.
good one
What did you use to clamp the engine to the drill press? Or did you do this with a hand drill?
I dont think my table drill press will be tall enough to do this, but I really like the idea!
Use a flap wheel instead
I did this with a hand drill, but Graham had the idea to turn a drill press table 90 degrees, clamp to it, and swivel it so it lines up with the chuck
I’m with Alex here. This seems like a whole lot more unnecessary effort with a lot more risk of fucking up your cases than just getting an oversized flap wheel and running it and checking until your kit fits into the bore.
> into the bore.
If you want to spend a few hours hunched over your cases with a hand drill just boring them out, thats fine. I've done that, hated it. Too tedious and time consuming. This isn't a contest really, just an alternative method that works really well and is no more likely to ruin things if you take the time and prepare and use quality tools
If it takes you hours to open up aluminum cases with a flap wheel you’re doing it wrong
> doing it wrong
What flap wheel are you using?
For most moped kits, you usually only need to bore cases by 2 or 3mm. This set of cases pictured needed to be bored by 8mm.
> doing it wrong
Psssshh I dont even know what a flap wheel is. Ha!
shut up nerds.
this + flap wheel clean up is definitely the cleanest way to bore that much without a rotary table mill. good idea.
Dirty30 Dillon /
100% a centered, rigid cutting tool is giving a better, more perpendicular bore than you're gettign with a flap wheel.
Brandon and I were chatting and I would def do this, but replace the drill bit in the hole saw with a smooth rod chucked in there, and wax the shit out of the shaft hole.
I also think this worked so well because Brandon was removing so much material.
I'd be interested to see if thin kerf hole saws are a thing?
Photo of finished cases? I like this
Blake Totally a real doctor /
I saw Charlie Buzzard do a similar thing like 10 years ago in their Sumter shop. He had a 2x4 bolted to the cases with a hole in the middle to center the hole saw. It took maybe 2 minutes and it was done.
I really hate the flap wheel method for anything more than a little material.
This is like a faster/cheaper version of the Malossi case bore tool.
🇮🇹💦 Of the Loin /
this is a really neat idea, I like that the tech is getting more advanced
I still prefer the ole "use a dremel and a tungsten carbide bit and maybe gouge your hand once" method.
If you hit your hand in that web between the thumb and first finger, you generally dont bleed much, especially if its the flat tipped bit
I'll get some, but they aren't going to be pretty :/ As mentioned above, I dint have the greatest start with it and I got a little close to some of the stud holes, so i added a little material with some alumiweld and some JB...it happened because my pilot hole was egg shaped from the drill bit not running true, and the hole saw not being true either...it was a cheap $8 set from harbor freight so that sums that up haha. Done with a high quality set and using Dillon's idea with a smooth shaft for the pilot instead of a drill bit, and a drill press jigged up, you'd get way better results im sure
I think I have some junk e50 cases laying around, i'll give it a shot with the drill press if I can jig it up.
High speed and slower progression will also help keep the bore true .
Just make a wooden buck with the hole saw diameter already in it that also has the cylinder bolt holes in it, bolt it to the cases and use that to start the hole.
No walking holesaw that way.
That's a GREAT idea, can't believe I didn't think of it!
Another possible method I was thinking about, although maybe too risky, is using a palm router with a template bit and a template with your desired bore, and you can slowly eat away at it. You can use them on aluminum, but you need to be careful with feed rates, too fast and it can grab.
> the chuck
Since someone with enough brain cells to comprehend, is actually paying attention, I'll set l one up and take a picture and post it, it works great. For a straight vertical plunge cut it's every bit as stable as a mill.
The discussion on FB, I was not picturing someone removing so much material, that's wild! Definitely worth the hole saw. I've also bought myself some real nice hole saws recently and they are way way way better than shitty ones.
> > the chuck
> mill.
> than shitty ones.
Looking forward to seeing it! I wonder if my little 10" craftsman can hold it. I'm in the market for a 12" machine though.
Kevin Bishop /
Go in reverse first and the cut will be smoother. Then switch to forward once you are an 1/8” deep.
