Re: EXHAUST CLEANING for a Puch Magnum Mk2
Probably Fred /
Remove the end cap by removing the 10 mm nut on the inside of it and bang it off with glancing blow’s at seam with a rubber mallet
You may have to heat it up a bit at the end because it may be stuck due to harden oil deposits then you can clean inside it
