Am I getting the correct performance
So I recently rebuilt my whole bottom end and top end on my moped I put a 70cc kit with high comp head, 27 x 22 sprokets, I believe 20lb first gear spring, 15 mm sha carb with 76 jet, 15 mm intake. Does 40mph sound about right for top speed? I also know I have a airleak at the intake because when I spray carb cleaner on it, it idles very low but I have turned it to idle fine with the airleak.
Re: Am I getting the correct performance
Vacuum leaks can kill performance so fix that first then see what it does.
Airleaks also kill pistons. You know where it is, fix it. They only get worse.
Strangely enough , air leaks never seem to fix themselves and always cause havoc . ;)
Luckily you have one of the easier leaks to fix. As everyone said, fix it now and enjoy a longer lasting engine and possibly better performance. I’d spend the 15 minutes and 5 bucks and replace the gasket.
