Malossi 4 petal reed Tomos intake mounting/direction...
Just wondering if the phbg intake part of the Malossi 4 petal reed kit faces backwards or forwards on a Tomos a35 Airsal cylinder.
I have all the pipes and rubber couplings / hose clamps etc. to extend the intake to meet the carb. (phbg 19) Will the intake scrape the frame at the bottom or will there be enough space for me to play with?
Cheers all.
Re: Malossi 4 petal reed Tomos intake mounting/direction...
You will need to fabricate an intake to work. when that pedal block is all assembled that intake that came with it will face straight upwards if I recall. I think MLM has an intake designed to fit tomos with that 4 pedal block.
Dirty30 Dillon /
Yeah, the malossi 4-petal block was made for Peugeot, not for Tomos.
Also, because of the bolt pattern there is really only one way the intake can go on after your mount the block.
I'll look into welding/brazing something up.
Thanks for the heads up.
