N8P specs
Luke Stroehlein /
Hey guys, anyone have the exact measurements of the n8p pipe? I'd love to weld a pipe with the same measurements. Let me know if you can help!
Re: N8P specs
I have one thats a flat port. Could take measurements this weekend
Re: N8P specs
Luke Stroehlein /
That would be awesome. Thank you
Re: N8P specs
These are kinda rough measued. Used a micrometer. You'll basically get a 2d rendering if you drar it out on paper.
Cone 1: 127mm long
33mm to 44mm
Cone 2: 67mm long
44mm to 49mm
Cone 3: 197mm
49mm to 90mm
Cone 4: 54mm long
90 to 90
Cone 5: 115mm long
90mm to 50mm
Baffel 185mm
Head 80mm 25mm port . Unfortunately i cant bend my micrometer so the length of a bent tube is a guesstimate.
Hope this helps. Good luck!
Re: N8P specs
Luke Stroehlein /
Awesome, thank you so much. Just to be clear when you say baffle is 185 you're talking about stinger length right? Also what was the ID of the stinger?
Re: N8P specs
Stinger is 185mm long. 50mm wide. Gotta do the ol algebruhhh! Like pie(r)² to get diameter or somethin like that. I guess i should have said that those are all radius measurements. Hope this helps.
