4 petal Malossi on pa50 ( way to easy!?)
Incelforlifebaby!hotandhorny69 646260 /
Why has no one tried using the stock pa50 reed block as a plate adapter!? (edited)
Re: 4 petal Malossi on pa50 ( way to easy!?)
It will fit!
Yes that is a pull start (edited)
Bolt clearance!
It’s real
I like it so much I made it from an aluminum plate
Toast
Mock up
Ricky Lacapria /
You have any issues with the pull start? Like if I got a head with no decomp, think it would be a nightmare to pull start it?
It depends on how much compression? I installed a pull start because the starter clutch stop working and I was like fuck it Il make a pull start. I’m running a stock kit and no decomp
Black pipe has as an article on a cheap diy pull start for Honda pa.
I used a cheetachrome paw then made a space so it would fit snug on the crank. it was easy, probably took me like 20min.
Finalized!
Haven’t test it yet because its been rainy here for like 3 days.
Carb is on a kinda extreme angle, doesn’t leak or anything but might want a different intake
Is your intake going to hit the frame when the shock compresses? Try to sit/bounce on it and see what it looks like?
It did! But I change the intake, I’ll post a photo tonight! It’s looks way better now
The carb was on an extreme as angle too
Better baby
no, that's how they work. Using a decomp while pull starting would be real dumb.
> real dumb.
No true, some chainsaw offer decomp during starting because of the crazy compression
> no
> > real dumb.
> compression
We're not talking about chainsaws
> > no
> be
> > > real dumb.
> crazy
> > compression
But we are lol
Dirty30 Dillon /
Mopeds =/= Chainsaws.
The physical weight, short stroke, and high compression of chain saws are the reason why you need a decomp. And even then, typically only to cold start.
I have never had an issue pull starting ANY moped.
anyway, this clever, surprised no one has though of using the stock black as an adapter. does it seal well?
I would imagine it would seal fine expect for the fact you drill the o-ring seal. So you’ll need to flatten it.
I just end up making one from a 1/4” aluminum plate. It’s works great but I didn’t see a performance gain on my stock cylinder lol Makes carb tuning easy and carb selection.
I would rip with a kit lol
all this for a baby clone sha!
Haha for now on a stock kit yes.
Easy to upgrade to a Big boy phbg with just the turn of a hose clamp! And tunning is just as simple
4 petal carbon Reeds! Big intake! Perfect for when I upgrade to a kit.
It took me maybe 3 hours top and I already had all the parts sitting on the self :)
