Hi guys, I decided to make a build thread for my Newport, there's not much left of the original bike but here it goes. I started this in 2014 when my professor gave me a moped that had been sitting in his garage since the 80s. It was super messed up and the engine was seized. I decided I wanted to build a blaster. Here are a few pics to start out with many more to come and the build list.
Build list:
Random:
-kx80 fork with rebuilt rim, shortened front springs, New brake pads, line, and fluid
-welded and modified frame with fuel cap moved to the side of the tank
-extended and reinforced rear swing arm
-gas rear shocks
-fabricated polished aluminum bars
-tachometer
-x grip phone mount
-magura clutch lever
-custom rear brake pedal system with treats shoes
-grimeca snowflake rear rim with sealed bearing conversion
-motion pro long pull throttle
-custom welded seat pan with brown leather jacket seat pad
-custom kickstand brace
Engine:
-ported, polished case with vacuum nipple added to crankcase
-fresh bearings and seals all around, case sealed with yamabond
-dmp crank with 11mm needle bearing
-lightened clutch bell with welded gear, machined to replace bushing with needle bearing
-1977 mopeds super clutch
-all hardware replaced with ss Allen bolts
-polini kit ported and case matched
-4 pedal Reed block
-silicone intake boot
-uni filter
-mikuni 14lph fuel pump
-mikuni tm24
- o ring head
-ngk R spark plug
-hpi mini rotor cdi system with weight
-ngk racing plug wire
-msd blaster ignition coil
-mlm Cali side bleed with packing removed
