Re: 17" Sebring Acorn to Disc
EH FCC of the QCB /
The front acorns are perfect for this. They actually have the area cast for the nuts to hold the rear sprocket on. I assume it was because they were all cast the same then some became fronts and some became rears. I leaned this too late after I used 2 rears on a bike to make a front disk brake setup. I was super bummed because all you have to do is drill out the holes, make some spacers, and use the gold 4 hole pit bike rotors.
