Re: Which Electronic ignition for Puch E50
EH 📣FCC of the QCB /
Everyone likes the “slap and go of CDIs”. Points are fine if they are in good condition and have been taken care of.
I don’t like the treats CDI. But I am pickey though. They are easy to set. Because if you put in in the right position it is “almost” fool proof. Full advance is like 1.8mm BTC. Retard the stator plate a bit and your around the 1.5mmBTDC range and so on. I mainly don’t like them because the trigger coil burns out quick. Last one I set I guessed it was at about 1.5mm BTDC at 1/4 till full advance in the slots. Checked it with the light and it was at 1.4mmBTDC. They are easy to set but the quality is not there.
Only messed with one MVT. I was not impressed. I think it had a bad box. Timing would jump all over the place. Thought it was the coil.....nope same ring with every coil I tried. Can’t speak on it too much because it was just one time.
HPI is about all I use if I don’t use stock points. They have the best lighting power and a decently easy to set. Just make sure you have a timing light to make sure the timing marks are correct on it.
  Which Electronic ignition for Puch E50Topic by: Bob Maxi Bob Maxi 03/24/20 05:23PM
  Re: Which Electronic ignition for Puch E50Re: Alex hernandez Alex hernandez 03/24/20 05:52PM
  Re: Which Electronic ignition for Puch E50Re: Bob Maxi Bob Maxi 03/24/20 05:58PM
  Re: Which Electronic ignition for Puch E50Re: Garelli Master✨ Garelli Master✨ 03/24/20 07:19PM
  Re: Which Electronic ignition for Puch E50Re: Probably Fred Probably Fred 03/24/20 05:55PM
  Re: Which Electronic ignition for Puch E50Re: EH 📣FCC of the QCB EH 📣FCC of the QCB 03/24/20 08:01PM
  Re: Which Electronic ignition for Puch E50Re: Luna Moto Luna Moto 03/25/20 12:26AM
  Re: Which Electronic ignition for Puch E50Re: 666 420 666 420 03/25/20 05:15AM
  Re: Which Electronic ignition for Puch E50Re: Bas Autowas Bas Autowas 03/25/20 07:50AM
  Re: Which Electronic ignition for Puch E50Re: Graham Motzing Graham Motzing 03/25/20 10:05AM
  Re: Which Electronic ignition for Puch E50Re: Mike Boyd Mike Boyd 03/25/20 01:36PM
  Re: Which Electronic ignition for Puch E50Re: Daniel '' Daniel '' 03/25/20 02:41PM
  Re: Which Electronic ignition for Puch E50Re: Rufus Von Rieles Rufus Von Rieles 06/04/20 05:04PM
  Re: Which Electronic ignition for Puch E50Re: Dirty30 Dillon Dirty30 Dillon 06/05/20 12:56AM
  Re: Which Electronic ignition for Puch E50Re: Jeff Parr Jeff Parr 03/25/20 05:45PM
  Re: Which Electronic ignition for Puch E50Re: Probably Fred Probably Fred 06/04/20 05:30PM
  Re: Which Electronic ignition for Puch E50Re: Rufus Von Rieles Rufus Von Rieles 06/04/20 06:00PM
  Re: Which Electronic ignition for Puch E50Re: Rufus Von Rieles Rufus Von Rieles 06/04/20 06:04PM
  Re: Which Electronic ignition for Puch E50Re: Thomas Peffer Thomas Peffer 06/04/20 08:31PM
  Re: Which Electronic ignition for Puch E50Re: Kevin Bishop Kevin Bishop 06/05/20 11:23PM
  Re: Which Electronic ignition for Puch E50Re: Rufus Von Rieles Rufus Von Rieles 06/06/20 11:32AM
