Re: Sachs clutch spring
Graham Motzing /
I shortened my spring, it was a bitch to put on but no glazing problems, I think that is just on the manual models. The centrifugal clutch pads hold but it spins on the shaft at a certain point.
You will need two needle nose vice grips, and shortening the spring doesn't help much, I dunno about the stiffer one. I was going to drill out the weights but I decided to just go with a 2m instead.
