Re: Puch Tech Bulletin 1.5-2 HP exhaust mod crucial detail left out...
Saabsonettguy . /
Each of the holes as a piece of tubing in it, the tubing is what you're trying to remove. I can't remember if its welded on one side or both sides, but you can probably tell when you look at it. You dont need to drill all the way through, just where the weld is.
