Re: Puch e50 tomar clutch??
Alex Hedrick /
> Daniel '' Wrote:
> It’s been done before. You have have have to have straight cut gears and
> a local machinist wizard to get it done properly. It’s not easy pease
> lemon squeezy, the tolerance is very very close to the main gear and you
> only get one shot at it. There is also the problem of making the bell
> bushing/needle bearing, since the crankshaft is only case hardened it
> gets blasted by the needle bearings under regular use. For a race bike
> it would probably be fine, but idling all the time would probably kill
> your crank. With drawn cup bearings you can’t get the tolerances tight
> enough without it wanting to bind up. I would recommend a custom cut
> bushing made from sintered aluminum or use loose needle rollers.
Well... good thing I am a machinist and have a lathe at the shop I work at and a mill in my garage! Haha I'm not worried about tight tolerances as I work with .0001 of inch all day every day.. should go smooth!
I know it's been done before.. but I've never seen reports back with results.. maybe I havent dug deep enough.. but I know I can make it work just fine and have it rip!
  Puch e50 tomar clutch??Topic by: Alex Hedrick Alex Hedrick 03/08/20 05:34PM
  Re: Puch e50 tomar clutch??Re: Daniel '' Daniel '' 03/08/20 06:16PM
  Re: Puch e50 tomar clutch??Re: Alex Hedrick Alex Hedrick 03/08/20 06:30PM
  Re: Puch e50 tomar clutch??Re: Daniel '' Daniel '' 03/08/20 07:20PM
  Re: Puch e50 tomar clutch??Re: Alex Hedrick Alex Hedrick 03/08/20 08:12PM
  Re: Puch e50 tomar clutch??Re: Daniel '' Daniel '' 03/08/20 08:21PM
  Re: Puch e50 tomar clutch??Re: EH FCC of the QCB EH FCC of the QCB 03/09/20 07:32AM
  Re: Puch e50 tomar clutch??Re: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 03/09/20 07:47AM
  Re: Puch e50 tomar clutch??Re: Dirty30 Dillon Dirty30 Dillon 03/09/20 11:26AM
  Re: Puch e50 tomar clutch??Re: Daniel '' Daniel '' 03/09/20 12:14PM
  Re: Puch e50 tomar clutch??Re: Derek Vanasse Derek Vanasse 05/31/20 07:10PM
  Re: Puch e50 tomar clutch??Re: Pritza R&D Pritza R&D 03/09/20 01:09PM
  Re: Puch e50 tomar clutch??Re: Born to be WillD Born to be WillD 03/09/20 03:51PM
  Re: Puch e50 tomar clutch??Re: Alex Hedrick Alex Hedrick 03/10/20 05:52AM
  Re: Puch e50 tomar clutch??Re: todd amundson todd amundson 03/11/20 12:03PM
  Re: Puch e50 tomar clutch??Re: jordan * jordan * 03/11/20 08:31PM
  Re: Puch e50 tomar clutch??Re: Alex Hedrick Alex Hedrick 03/12/20 10:26AM
  Re: Puch e50 tomar clutch??Re: Alex Hedrick Alex Hedrick 03/12/20 04:42AM
  Re: Puch e50 tomar clutch??Re: Alex Hedrick Alex Hedrick 03/12/20 04:46AM
  Re: Puch e50 tomar clutch??Re: Alex Hedrick Alex Hedrick 03/12/20 04:51AM
  Re: Puch e50 tomar clutch??Re: Alex Hedrick Alex Hedrick 03/15/20 09:20AM
  Re: Puch e50 tomar clutch??Re: Alex Hedrick Alex Hedrick 03/19/20 07:07PM
  Re: Puch e50 tomar clutch??Re: Louis Brunskill Louis Brunskill 03/21/20 02:59PM
  Re: Puch e50 tomar clutch??Re: Alex Hedrick Alex Hedrick 03/21/20 04:35PM
  Re: Puch e50 tomar clutch??Re: Louis Brunskill Louis Brunskill 03/21/20 03:00PM
  Re: Puch e50 tomar clutch??Re: Louis Brunskill Louis Brunskill 03/21/20 03:08PM
  Re: Puch e50 tomar clutch??Re: Alex Hedrick Alex Hedrick 03/21/20 04:36PM
  Re: Puch e50 tomar clutch??Re: Alex Hedrick Alex Hedrick 03/21/20 04:38PM
  Re: Puch e50 tomar clutch??Re: Alex Hedrick Alex Hedrick 03/22/20 01:56PM
  Re: Puch e50 tomar clutch??Re: SEAN BILLINGY SEAN BILLINGY 03/30/20 01:08PM
  Re: Puch e50 tomar clutch??Re: Louis Brunskill Louis Brunskill 03/30/20 06:48PM
  Re: Puch e50 tomar clutch??Re: 666 420 666 420 03/30/20 11:38PM
  Re: Puch e50 tomar clutch??Re: Alex Hedrick Alex Hedrick 03/31/20 05:36AM
  Re: Puch e50 tomar clutch??Re: Dirty30 Dillon Dirty30 Dillon 03/31/20 07:55AM
  Re: Puch e50 tomar clutch??Re: todd amundson todd amundson 03/31/20 12:05PM
  Re: Puch e50 tomar clutch??Re: 666 420 666 420 03/31/20 04:02PM
  Re: Puch e50 tomar clutch??Re: Alex Hedrick Alex Hedrick 03/31/20 10:33PM
  Re: Puch e50 tomar clutch??Re: Ian c Ian c 03/31/20 11:13PM
  Re: Puch e50 tomar clutch??Re: 666 420 666 420 03/31/20 11:29PM
  Re: Puch e50 tomar clutch??Re: Alex Hedrick Alex Hedrick 04/01/20 04:59PM
  Re: Puch e50 tomar clutch??Re: 666 420 666 420 04/01/20 07:46PM
  Re: Puch e50 tomar clutch??Re: Alex Hedrick Alex Hedrick 04/01/20 11:01PM
  Re: Puch e50 tomar clutch??Re: Mike Boyd Mike Boyd 05/30/20 09:42PM
  Re: Puch e50 tomar clutch??Re: Alex Hedrick Alex Hedrick 03/31/20 05:41AM
  Re: Puch e50 tomar clutch??Re: Jesse Stephenson Jesse Stephenson 04/01/20 08:47PM
  Re: Puch e50 tomar clutch??Re: jordan * jordan * 05/30/20 09:38PM
  Re: Puch e50 tomar clutch??Re: Alex Hedrick Alex Hedrick 06/03/20 04:45AM
  Re: Puch e50 tomar clutch??Re: 666 420 666 420 06/03/20 05:13AM
  Re: Puch e50 tomar clutch??Re: Alex Hedrick Alex Hedrick 06/15/20 09:08PM
  Re: Puch e50 tomar clutch??Re: todd amundson todd amundson 06/17/20 02:56PM
  Re: Puch e50 tomar clutch??Re: 666 420 666 420 05/31/20 12:16AM
  Re: Puch e50 tomar clutch??Re: Derek Vanasse Derek Vanasse 05/31/20 07:16PM
  Re: Puch e50 tomar clutch??Re: 666 420 666 420 06/17/20 05:08PM
  Re: Puch e50 tomar clutch??Re: Alex Hedrick Alex Hedrick 06/18/20 05:43AM
  Re: Puch e50 tomar clutch??Re: Dirty30 Dillon Dirty30 Dillon 06/18/20 09:59AM
  Re: Puch e50 tomar clutch??Re: 666 420 666 420 06/18/20 03:09PM
  Re: Puch e50 tomar clutch??Re: Dirty30 Dillon Dirty30 Dillon 06/18/20 03:20PM
  Re: Puch e50 tomar clutch??Re: 666 420 666 420 06/18/20 04:19PM
  Re: Puch e50 tomar clutch??Re: Dirty30 Dillon Dirty30 Dillon 06/18/20 04:27PM
  Re: Puch e50 tomar clutch??Re: 666 420 666 420 06/18/20 04:38PM
  Re: Puch e50 tomar clutch??Re: Alex Hedrick Alex Hedrick 06/28/20 06:59AM
  Re: Puch e50 tomar clutch??Re: Alex Hedrick Alex Hedrick 06/28/20 02:22PM
  Re: Puch e50 tomar clutch??Re: Alex Hedrick Alex Hedrick 06/28/20 02:24PM
  Re: Puch e50 tomar clutch??Re: 666 420 666 420 06/28/20 04:32PM
  Re: Puch e50 tomar clutch??Re: Alex Hedrick Alex Hedrick 06/28/20 06:58PM
  Re: Puch e50 tomar clutch??Re: Jay Rivett Jay Rivett 06/29/20 09:13PM
  Re: Puch e50 tomar clutch??Re: Dirty30 Dillon Dirty30 Dillon 07/04/20 03:43PM
  Re: Puch e50 tomar clutch??Re: Alex Hedrick Alex Hedrick 07/04/20 03:02AM
  Re: Puch e50 tomar clutch??Re: Ryan Graeme Ryan Graeme 07/04/20 06:52AM
  Re: Puch e50 tomar clutch??Re: 666 420 666 420 07/04/20 02:41PM
  Re: Puch e50 tomar clutch??Re: Alex Hedrick Alex Hedrick 07/04/20 05:25PM
  Re: Puch e50 tomar clutch??Re: EH FCC of the QCB EH FCC of the QCB 07/05/20 12:01PM
  Re: Puch e50 tomar clutch??Re: Alex Hedrick Alex Hedrick 07/05/20 04:50PM
  Re: Puch e50 tomar clutch??Re: EH FCC of the QCB EH FCC of the QCB 07/05/20 08:51PM
  Re: Puch e50 tomar clutch??Re: Alex Hedrick Alex Hedrick 07/04/20 03:03AM
  Re: Puch e50 tomar clutch??Re: Alex Hedrick Alex Hedrick 07/04/20 09:21PM
  Re: Puch e50 tomar clutch??Re: 666 420 666 420 07/05/20 01:11AM
  Re: Puch e50 tomar clutch??Re: Aaron Blair Aaron Blair 07/05/20 11:16PM
  Re: Puch e50 tomar clutch??Re: 666 420 666 420 07/05/20 11:42PM
  Re: Puch e50 tomar clutch??Re: Alex Hedrick Alex Hedrick 07/06/20 04:37AM
  Re: Puch e50 tomar clutch??Re: 666 420 666 420 07/06/20 11:05PM
  Re: Puch e50 tomar clutch??Re: Alex Hedrick Alex Hedrick 07/07/20 03:05PM
  Re: Puch e50 tomar clutch??Re: Dirty30 Dillon Dirty30 Dillon 07/07/20 04:39PM
  Re: Puch e50 tomar clutch??Re: P D P D 07/07/20 05:07PM
  Re: Puch e50 tomar clutch??Re: Alex Hedrick Alex Hedrick 07/07/20 07:42PM
  Re: Puch e50 tomar clutch??Re: Dirty30 Dillon Dirty30 Dillon 07/07/20 11:02PM
  Re: Puch e50 tomar clutch??Re: Alex Hedrick Alex Hedrick 07/05/20 09:20PM
  Re: Puch e50 tomar clutch??Re: 666 420 666 420 07/07/20 11:09PM
  Re: Puch e50 tomar clutch??Re: Dirty30 Dillon Dirty30 Dillon 07/07/20 11:32PM
  Re: Puch e50 tomar clutch??Re: 666 420 666 420 07/08/20 12:39AM
  Re: Puch e50 tomar clutch??Re: Daniel '' Daniel '' 07/08/20 04:57PM
  Re: Puch e50 tomar clutch??Re: Dirty30 Dillon Dirty30 Dillon 07/08/20 05:00PM
  Re: Puch e50 tomar clutch??Re: 666 420 666 420 07/08/20 05:00PM
  Re: Puch e50 tomar clutch??Re: Jay Rivett Jay Rivett 07/08/20 07:35PM
  Re: Puch e50 tomar clutch??Re: T y l e r T y l e r 07/09/20 02:47PM
  Re: Puch e50 tomar clutch??Re: Graham Motzing Graham Motzing 07/28/20 01:51AM
  Re: Puch e50 tomar clutch??Re: 666 420 666 420 07/28/20 02:52AM
  Re: Puch e50 tomar clutch??Re: MM Racing MM Racing 07/27/20 12:43PM
  Re: Puch e50 tomar clutch??Re: Born to be WillD Born to be WillD 07/27/20 01:51PM
  Re: Puch e50 tomar clutch??Re: T y l e r T y l e r 07/27/20 04:38PM
  Re: Puch e50 tomar clutch??Re: Born to be WillD Born to be WillD 08/04/20 03:52PM
  Re: Puch e50 tomar clutch??Re: 666 420 666 420 07/28/20 12:07AM
  Re: Puch e50 tomar clutch??Re: Alex Hedrick Alex Hedrick 08/02/20 02:16PM
  Re: Puch e50 tomar clutch??Re: 666 420 666 420 08/02/20 02:57PM
  Re: Puch e50 tomar clutch??Re: Alex Hedrick Alex Hedrick 08/02/20 03:05PM
  Re: Puch e50 tomar clutch??Re: Trevor McGrath Trevor McGrath 08/02/20 03:32PM
  Re: Puch e50 tomar clutch??Re: Daniel '' Daniel '' 08/05/20 07:38AM
  Re: Puch e50 tomar clutch??Re: Ryan Graeme Ryan Graeme 08/02/20 04:10PM
  Re: Puch e50 tomar clutch??Re: Papa _ Papa _ 08/05/20 07:53AM
  Re: Puch e50 tomar clutch??Re: 666 420 666 420 08/05/20 05:35PM
  Re: Puch e50 tomar clutch??Re: Alex Hedrick Alex Hedrick 08/15/20 05:57AM
  Re: Puch e50 tomar clutch??Re: Jay Rivett Jay Rivett 08/15/20 12:42PM
  Re: Puch e50 tomar clutch??Re: 666 420 666 420 11/18/20 06:54PM
  Re: Puch e50 tomar clutch??Re: classic carl jepsen classic carl jepsen 11/18/20 07:13PM
  Re: Puch e50 tomar clutch??Re: jordan * jordan * 11/19/20 05:41PM
  Re: Puch e50 tomar clutch??Re: P D P D 11/19/20 06:03PM
  Re: Puch e50 tomar clutch??Re: 666 420 666 420 11/19/20 11:09PM
  Re: Puch e50 tomar clutch??Re: Alex Hedrick Alex Hedrick 11/25/20 05:36AM
  Re: Puch e50 tomar clutch??Re: 666 420 666 420 11/25/20 06:31AM
  Re: Puch e50 tomar clutch??Re: EH FCC of the QCB EH FCC of the QCB 11/26/20 09:48AM
  Re: Puch e50 tomar clutch??Re: Papa _ Papa _ 11/26/20 10:25AM
  Re: Puch e50 tomar clutch??Re: Alex Hedrick Alex Hedrick 11/26/20 10:45AM
  Re: Puch e50 tomar clutch??Re: 666 420 666 420 11/26/20 02:08PM
  Re: Puch e50 tomar clutch??Re: Alex Hedrick Alex Hedrick 11/26/20 02:32PM
  Re: Puch e50 tomar clutch??Re: 666 420 666 420 11/26/20 02:35PM
  Re: Puch e50 tomar clutch??Re: Alex Hedrick Alex Hedrick 11/26/20 03:20PM
  Re: Puch e50 tomar clutch??Re: P D P D 11/26/20 03:59PM
  Re: Puch e50 tomar clutch??Re: Alex Hedrick Alex Hedrick 11/26/20 04:26PM
  Re: Puch e50 tomar clutch??Re: 666 420 666 420 11/26/20 06:07PM
  Re: Puch e50 tomar clutch??Re: Dirty30 Dillon Dirty30 Dillon 11/27/20 11:07AM
  Re: Puch e50 tomar clutch??Re: Alex Hedrick Alex Hedrick 11/27/20 11:18AM
  Re: Puch e50 tomar clutch??Re: 666 420 666 420 11/27/20 05:44PM
  Re: Puch e50 tomar clutch??Re: Alex Hedrick Alex Hedrick 11/27/20 07:30PM
  Re: Puch e50 tomar clutch??Re: Dirty30 Dillon Dirty30 Dillon 11/27/20 08:00PM
  Re: Puch e50 tomar clutch??Re: Alex Hedrick Alex Hedrick 11/27/20 08:15PM
  Re: Puch e50 tomar clutch??Re: 666 420 666 420 11/28/20 02:38AM
  Re: Puch e50 tomar clutch??Re: Jay Rivett Jay Rivett 11/27/20 12:50AM
  Re: Puch e50 tomar clutch??Re: Papa _ Papa _ 11/26/20 11:03AM
  Re: Puch e50 tomar clutch??Re: Alex Hedrick Alex Hedrick 11/26/20 11:21AM
  Re: Puch e50 tomar clutch??Re: Papa _ Papa _ 11/27/20 02:35AM
  Re: Puch e50 tomar clutch??Re: 666 420 666 420 11/27/20 03:36AM
  Re: Puch e50 tomar clutch??Re: Sander Mulder Sander Mulder 11/29/20 07:59AM
  Re: Puch e50 tomar clutch??Re: 666 420 666 420 11/29/20 03:04PM
  Re: Puch e50 tomar clutch??Re: EH FCC of the QCB EH FCC of the QCB 11/29/20 07:03PM
  Re: Puch e50 tomar clutch??Re: 666 420 666 420 11/30/20 02:20AM
  Re: Puch e50 tomar clutch??Re: 666 420 666 420 12/12/20 08:15PM
  Re: Puch e50 tomar clutch??Re: Thomas Peffer Thomas Peffer 09/05/21 11:35PM
  Re: Puch e50 tomar clutch??Re: 666 420 666 420 09/06/21 01:05AM
  Re: Puch e50 tomar clutch??Re: Alex Hedrick Alex Hedrick 09/06/21 01:51AM
  Re: Puch e50 tomar clutch??Re: Alex Hedrick Alex Hedrick 09/06/21 02:09AM
  Re: Puch e50 tomar clutch??Re: Graham Motzing Graham Motzing 09/07/21 10:46AM
  Re: Puch e50 tomar clutch??Re: Graham Motzing Graham Motzing 09/06/21 09:50PM
  Re: Puch e50 tomar clutch??Re: 666 420 666 420 09/07/21 01:28PM
  Re: Puch e50 tomar clutch??Re: * wormdirt * * wormdirt * 09/07/21 09:27PM
  Re: Puch e50 tomar clutch??Re: 666 420 666 420 09/28/21 04:37PM
  Re: Puch e50 tomar clutch??Re: Thomas Peffer Thomas Peffer 09/29/21 04:35PM
  Re: Puch e50 tomar clutch??Re: 666 420 666 420 09/29/21 06:36PM
  Re: Puch e50 tomar clutch??Re: daan SJAARLOOS daan SJAARLOOS 09/06/21 02:28AM
  Re: Puch e50 tomar clutch??Re: daan SJAARLOOS daan SJAARLOOS 09/06/21 02:32AM
  Re: Puch e50 tomar clutch??Re: 666 420 666 420 09/06/21 11:25AM
  Re: Puch e50 tomar clutch??Re: Thomas Peffer Thomas Peffer 09/06/21 08:58PM
  Re: Puch e50 tomar clutch??Re: Mike Boyd Mike Boyd 09/07/21 12:30AM
  Re: Puch e50 tomar clutch??Re: EH FCC of the QCB EH FCC of the QCB 09/07/21 04:26AM
  Re: Puch e50 tomar clutch??Re: daan SJAARLOOS daan SJAARLOOS 09/07/21 04:26AM
  Re: Puch e50 tomar clutch??Re: LSLB RXb LSLB RXb 09/07/21 01:01AM
  Re: Puch e50 tomar clutch??Re: EH FCC of the QCB EH FCC of the QCB 09/06/21 09:01PM
  Re: Puch e50 tomar clutch??Re: jordan * jordan * 09/06/21 09:55PM
  Re: Puch e50 tomar clutch??Re: Thomas Peffer Thomas Peffer 09/06/21 10:13PM
  Re: Puch e50 tomar clutch??Re: Thomas Peffer Thomas Peffer 09/06/21 10:24PM
  Re: Puch e50 tomar clutch??Re: jordan * jordan * 09/06/21 10:35PM
  Re: Puch e50 tomar clutch??Re: Thomas Peffer Thomas Peffer 09/06/21 10:50PM
  Re: Puch e50 tomar clutch??Re: daan SJAARLOOS daan SJAARLOOS 09/07/21 03:35AM
  Re: Puch e50 tomar clutch??Re: Ryan Graeme Ryan Graeme 09/07/21 01:04AM
  Re: Puch e50 tomar clutch??Re: Thomas Peffer Thomas Peffer 09/07/21 09:44AM
  Re: Puch e50 tomar clutch??Re: Born to be WillD Born to be WillD 09/07/21 10:38AM
  Re: Puch e50 tomar clutch??Re: Thomas Peffer Thomas Peffer 09/07/21 10:54AM
  Re: Puch e50 tomar clutch??Re: daan SJAARLOOS daan SJAARLOOS 09/07/21 12:35PM
  Re: Puch e50 tomar clutch??Re: daan SJAARLOOS daan SJAARLOOS 09/07/21 12:57PM
  Re: Puch e50 tomar clutch??Re: Thomas Peffer Thomas Peffer 09/07/21 10:00PM
  Re: Puch e50 tomar clutch??Re: Dickie Thompson Dickie Thompson 09/28/21 12:39PM
  Re: Puch e50 tomar clutch??Re: Garrett The Kid Garrett The Kid 09/30/21 10:51AM
  Re: Puch e50 tomar clutch??Re: Graham Motzing Graham Motzing 09/30/21 12:24PM
  Re: Puch e50 tomar clutch??Re: LSLB RXb LSLB RXb 10/01/21 07:45AM
  Re: Puch e50 tomar clutch??Re: Thomas Peffer Thomas Peffer 09/30/21 05:57PM
  Re: Puch e50 tomar clutch??Re: Pavo Z Pavo Z 10/01/21 05:08AM
  Re: Puch e50 tomar clutch??Re: 666 420 666 420 10/01/21 06:44PM
  Re: Puch e50 tomar clutch??Re: Jesse Stephenson Jesse Stephenson 10/02/21 01:15PM
  Re: Puch e50 tomar clutch??Re: Graham Motzing Graham Motzing 10/02/21 03:06PM
  Re: Puch e50 tomar clutch??Re: P D P D 10/02/21 04:28PM
  Re: Puch e50 tomar clutch??Re: Jesse Stephenson Jesse Stephenson 10/02/21 04:29PM
  Re: Puch e50 tomar clutch??Re: Stephen Simmons Stephen Simmons 10/03/21 05:46AM
  Re: Puch e50 tomar clutch??Re: 666 420 666 420 10/02/21 08:12PM
  Re: Puch e50 tomar clutch??Re: Jesse Stephenson Jesse Stephenson 10/02/21 10:19PM
  Re: Puch e50 tomar clutch??Re: 666 420 666 420 10/02/21 10:33PM
