80cc Athena jetting question
Does anybody know anything about jetting sizes for an 80cc Athena?
Running a 15mm Bing 2.17 atomizer 78 jet 2nd ring from top
Re: 80cc Athena jetting question
Overpriced Parts /
If sach Reed kit should be higher jet but it depends what filter you use and if you’re using metal reeds I suggest you change them to fiber ones
80cc non reed Athena. Jet size
Pipe? Elevation? Filter?
The question needs more information to give a better answer.
Following for info.
I'd start mid 90s. I dunno anyone running such a small carb on such a big kit, it's pretty comparable to like the 74cc airsal or metrakit - puch's big "80cc" piston ports; and those everybody runs at least a VM18 if not PHBG21 or TM24.
But folks use 15bings on polinis all the time, high 80s jetting
I'm at 0ft elevation. My pipe is a tomos estoril custom sidebleed and shorter header. 15mm Bing. 78 jet currently.
No filter as of yet.....thinking inline check valve.
