Bought a magnum with a treats kit, stock head. It's got an ngk b6hs in it. Gapped around 25 thou.
Runs n drives fine just curious what others run with this setup.
Thanks
Thanks
A B6HS is too hot a plug for a kit. Run a B7HS. Also the gap should be between .016 and .020
Before you take the above advice, check your plug to see if it looks like it's too hot.
Just arbitrarily following internet advice like "you need this plug" isn't a good way to tune your bike.
