> EH FCC of the QCB Wrote:
> Based on the zip tie cable extension and red tape over a bike light, you
> probably have more to worry about then which pipe will give you a mile
> per hour faster.
> I honestly have not been able to tell a huge difference in performance
> in the 2 pipes. The Estoril is a way better pipe with the lows and the
> mids being much nicer. But as far as top end it may only be a couple
> miles per hour difference.
> Now the only question. Do you know how to tune your carburetor for the
> pipe? If so I would put the Estoril on there and tune it correctly and
> look up how to correct the size on your brake cables. Buy some Knaps
> or make your own by drilling a hole in a bolt. That whole thing looks
> like a recipe for not being able to stop when you need to.
How would one tune a carb to let say....that estoril? I thought a carb tune was a carb tune, teach me.
