Re: Which exhaust is better on a kitted Magnum
Probably Fred /
> EH FCC of the QCB Wrote:
> Based on the zip tie cable extension and red tape over a bike light, you
> probably have more to worry about then which pipe will give you a mile
> per hour faster.
> I honestly have not been able to tell a huge difference in performance
> in the 2 pipes. The Estoril is a way better pipe with the lows and the
> mids being much nicer. But as far as top end it may only be a couple
> miles per hour difference.
> Now the only question. Do you know how to tune your carburetor for the
> pipe? If so I would put the Estoril on there and tune it correctly and
> look up how to correct the size on your brake cables. Buy some Knaps
> or make your own by drilling a hole in a bolt. That whole thing looks
> like a recipe for not being able to stop when you need to.
The cables though they need fixing aren’t necessarily his fault, the aftermarket puch cables I’ve been complaining about for years because the internal cables many times are made too long compared to a stock cable,
I think benji corrected the problem on latest batch of puch cables he sells but otherwise you need to stock nos puch ones, I don’t like using Karps on brake cables because they crush some of the cable flat weakening it
(When you crimp a twisted cable flat some strands are tight and some are loose, it decrease the strength by 30-40%) as well as making a corrosion point and it can fail, having custom length with cast metal ends like motorcycle shops used to do back in the day is best,
They do make a adjuster you can add before the other adjuster that I’ve used a few times instead of cutting the cable and crimping it flat,
  Which exhaust is better on a kitted MagnumTopic by: Reed Hois Reed Hois 02/29/20 04:33PM
  Re: Which exhaust is better on a kitted MagnumRe: P D P D 02/29/20 04:45PM
  Re: Which exhaust is better on a kitted MagnumRe: Chris Straub Chris Straub 02/29/20 10:55PM
  Re: Which exhaust is better on a kitted MagnumRe: Aaron Goldman Aaron Goldman 03/01/20 08:00AM
  Re: Which exhaust is better on a kitted MagnumRe: live ɘvil live ɘvil 03/01/20 09:24AM
  Re: Which exhaust is better on a kitted MagnumRe: Richard Eberline Richard Eberline 03/01/20 08:49AM
  Re: Which exhaust is better on a kitted MagnumRe: Satan 666 Satan 666 03/01/20 10:10AM
  Re: Which exhaust is better on a kitted MagnumRe: live ɘvil live ɘvil 03/01/20 10:55AM
  Re: Which exhaust is better on a kitted MagnumRe: P D P D 03/01/20 01:07PM
  Re: Which exhaust is better on a kitted MagnumRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 03/01/20 03:45PM
  Re: Which exhaust is better on a kitted MagnumRe: Probably Fred Probably Fred 03/01/20 04:42PM
  Re: Which exhaust is better on a kitted MagnumRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 03/01/20 06:50PM
  Re: Which exhaust is better on a kitted MagnumRe: Probably Fred Probably Fred 03/02/20 01:54AM
  Re: Which exhaust is better on a kitted MagnumRe: . Chudas. . Chudas. 03/02/20 09:26AM
  Re: Which exhaust is better on a kitted MagnumRe: P D P D 03/02/20 10:35AM
  Re: Which exhaust is better on a kitted MagnumRe: Satan 666 Satan 666 03/02/20 10:46AM
  Re: Which exhaust is better on a kitted MagnumRe: P D P D 03/02/20 11:10AM
  Re: Which exhaust is better on a kitted MagnumRe: . Chudas. . Chudas. 03/02/20 02:26PM
  Re: Which exhaust is better on a kitted MagnumRe: Graham Motzing Graham Motzing 03/02/20 05:19PM
  Re: Which exhaust is better on a kitted MagnumRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 03/03/20 06:11PM
