Re: Moby vs 103 50cc’s: your thoughts?
Daniel '' /
Eh for most of the 50cc Peugeot kits if you didn’t port it or space the cylinder the stock clutch pulley springs are almost too stiff. Getting the belt all the way into the front pulley and the gearing right is the biggest thing. Typically on high revving kits if you have too much gear you end up not reaching max rpm or full variation. If you go fucking with the spring tension and increase it too much it makes the engagement super violent and will make your variator unthread itself, if you fix that it will break the blue piece or at worst the crank will go snappy snappy and send your fancy variator into a ravine.
  Moby vs 103 50cc’s: your thoughts?Topic by: Toledo Riot Toledo Riot 02/27/20 04:08PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: jumpsuit steve jumpsuit steve 02/27/20 04:51PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Toledo Riot Toledo Riot 02/27/20 05:15PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: JBOT Admin JBOT Admin 02/27/20 05:10PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Toledo Riot Toledo Riot 02/27/20 05:18PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: EH FCC of the QCB EH FCC of the QCB 02/27/20 09:08PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: jumpsuit steve jumpsuit steve 02/27/20 11:48PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Toledo Riot Toledo Riot 02/28/20 12:07PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: JBOT Admin JBOT Admin 02/28/20 12:32PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Travis King Travis King 02/28/20 10:42PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: JBOT Admin JBOT Admin 02/28/20 11:38PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Travis King Travis King 02/28/20 10:47PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Toledo Riot Toledo Riot 02/29/20 12:28AM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Toledo Riot Toledo Riot 03/01/20 02:03PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: JBOT Admin JBOT Admin 03/01/20 02:47PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Daniel '' Daniel '' 03/01/20 06:11PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Graham Motzing Graham Motzing 03/02/20 12:58PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Toledo Riot Toledo Riot 03/02/20 02:11PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Toledo Riot Toledo Riot 03/02/20 12:54PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: JBOT Admin JBOT Admin 03/02/20 01:31PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Daniel '' Daniel '' 03/02/20 03:04PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Toledo Riot Toledo Riot 03/02/20 03:50PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Toledo Riot Toledo Riot 03/04/20 11:27PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Daniel '' Daniel '' 03/05/20 02:19AM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Toledo Riot Toledo Riot 03/05/20 09:50AM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Daniel '' Daniel '' 03/05/20 09:53PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Toledo Riot Toledo Riot 03/06/20 09:27AM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Dirty Mike Dirty Mike 03/06/20 10:26AM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Daniel '' Daniel '' 03/06/20 02:27PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Dirty Mike Dirty Mike 03/06/20 04:59PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Toledo Riot Toledo Riot 03/06/20 05:13PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Zach Riddle Zach Riddle 03/08/20 11:19AM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Daniel '' Daniel '' 03/08/20 01:52PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Zach Riddle Zach Riddle 03/08/20 07:42PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Daniel '' Daniel '' 03/08/20 08:23PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Toledo Riot Toledo Riot 03/09/20 11:11AM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Toledo Riot Toledo Riot 03/13/20 09:51AM
