Re: Moby vs 103 50cc’s: your thoughts?
Toledo Riot /
Ok I tried some variations
First test was stock vario, no clutch shoes, m6 nuts for weights, one star washer, no balls, so the variator was essentially clutch-less, it performed about as well as the same vario with a clutch function, maybe slightly slightly better due to the lower weight
For the second test I used a clutch-less er3 from a Moby, spaced it out to get the belt alignment proper, and boom fucking screams off the line, I doubt this motor will last long with these rpms off the line, buuuut it will be fun while it lasts
  Moby vs 103 50cc’s: your thoughts?Topic by: Toledo Riot Toledo Riot 02/27/20 04:08PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: jumpsuit steve jumpsuit steve 02/27/20 04:51PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Toledo Riot Toledo Riot 02/27/20 05:15PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Totally normal JBOT Totally normal JBOT 02/27/20 05:10PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Toledo Riot Toledo Riot 02/27/20 05:18PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: EH FCC of the QCB EH FCC of the QCB 02/27/20 09:08PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: jumpsuit steve jumpsuit steve 02/27/20 11:48PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Toledo Riot Toledo Riot 02/28/20 12:07PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Totally normal JBOT Totally normal JBOT 02/28/20 12:32PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Travis King Travis King 02/28/20 10:42PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Totally normal JBOT Totally normal JBOT 02/28/20 11:38PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Travis King Travis King 02/28/20 10:47PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Toledo Riot Toledo Riot 02/29/20 12:28AM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Toledo Riot Toledo Riot 03/01/20 02:03PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Totally normal JBOT Totally normal JBOT 03/01/20 02:47PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Daniel '' Daniel '' 03/01/20 06:11PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Graham Motzing Graham Motzing 03/02/20 12:58PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Toledo Riot Toledo Riot 03/02/20 02:11PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Toledo Riot Toledo Riot 03/02/20 12:54PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Totally normal JBOT Totally normal JBOT 03/02/20 01:31PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Daniel '' Daniel '' 03/02/20 03:04PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Toledo Riot Toledo Riot 03/02/20 03:50PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Toledo Riot Toledo Riot 03/04/20 11:27PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Daniel '' Daniel '' 03/05/20 02:19AM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Toledo Riot Toledo Riot 03/05/20 09:50AM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Daniel '' Daniel '' 03/05/20 09:53PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Toledo Riot Toledo Riot 03/06/20 09:27AM
  Re: Moby vs 103 50cc’s: your thoughts?Re: The Real Mike D The Real Mike D 03/06/20 10:26AM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Daniel '' Daniel '' 03/06/20 02:27PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: The Real Mike D The Real Mike D 03/06/20 04:59PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Toledo Riot Toledo Riot 03/06/20 05:13PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Zach Riddle Zach Riddle 03/08/20 11:19AM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Daniel '' Daniel '' 03/08/20 01:52PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Zach Riddle Zach Riddle 03/08/20 07:42PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Daniel '' Daniel '' 03/08/20 08:23PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Toledo Riot Toledo Riot 03/09/20 11:11AM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Toledo Riot Toledo Riot 03/13/20 09:51AM
