Re: Moby vs 103 50cc’s: your thoughts?
Toledo Riot /
> EH FCC of the QCB Wrote:
> Can’t you do something like weld the plates together to remove the
> clutch part of the front 103 Vairo so it only used the clutch pulley? I
> think that would be interesting.
you can remove the starter clutch arms to save weight then flip that one washer that sits behind the fixed cheek, that will lock the stock vario so it no longer works in a "clutch'd" manner, Im going to try this, and the ER3 on Sunday, see which set up works best
> jumpsuit steve Wrote:
> Andy - My instinct was to guess you were slipping too much, but it
> really sound like you maybe aren't slipping enough? I would put a tach
> on it and see where the clutch is hitting relative to your powerband.
You could be right, but I was also holding a phone, using one hand for brakes and throttle in a small space, so it may not be the perfect example of how its really reving, regardless I take your point and will keep it in mind when tuning further!
  Moby vs 103 50cc’s: your thoughts?Topic by: Toledo Riot Toledo Riot 02/27/20 04:08PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: jumpsuit steve jumpsuit steve 02/27/20 04:51PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Toledo Riot Toledo Riot 02/27/20 05:15PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: JBOT Admin JBOT Admin 02/27/20 05:10PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Toledo Riot Toledo Riot 02/27/20 05:18PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: EH FCC of the QCB EH FCC of the QCB 02/27/20 09:08PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: jumpsuit steve jumpsuit steve 02/27/20 11:48PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Toledo Riot Toledo Riot 02/28/20 12:07PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: JBOT Admin JBOT Admin 02/28/20 12:32PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Travis King Travis King 02/28/20 10:42PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: JBOT Admin JBOT Admin 02/28/20 11:38PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Travis King Travis King 02/28/20 10:47PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Toledo Riot Toledo Riot 02/29/20 12:28AM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Toledo Riot Toledo Riot 03/01/20 02:03PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: JBOT Admin JBOT Admin 03/01/20 02:47PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Daniel '' Daniel '' 03/01/20 06:11PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Graham Motzing Graham Motzing 03/02/20 12:58PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Toledo Riot Toledo Riot 03/02/20 02:11PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Toledo Riot Toledo Riot 03/02/20 12:54PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: JBOT Admin JBOT Admin 03/02/20 01:31PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Daniel '' Daniel '' 03/02/20 03:04PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Toledo Riot Toledo Riot 03/02/20 03:50PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Toledo Riot Toledo Riot 03/04/20 11:27PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Daniel '' Daniel '' 03/05/20 02:19AM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Toledo Riot Toledo Riot 03/05/20 09:50AM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Daniel '' Daniel '' 03/05/20 09:53PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Toledo Riot Toledo Riot 03/06/20 09:27AM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Dirty Mike Dirty Mike 03/06/20 10:26AM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Daniel '' Daniel '' 03/06/20 02:27PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Dirty Mike Dirty Mike 03/06/20 04:59PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Toledo Riot Toledo Riot 03/06/20 05:13PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Zach Riddle Zach Riddle 03/08/20 11:19AM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Daniel '' Daniel '' 03/08/20 01:52PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Zach Riddle Zach Riddle 03/08/20 07:42PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Daniel '' Daniel '' 03/08/20 08:23PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Toledo Riot Toledo Riot 03/09/20 11:11AM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Toledo Riot Toledo Riot 03/13/20 09:51AM
