Re: Moby vs 103 50cc’s: your thoughts?
jumpsuit steve /
> EH FCC of the QCB Wrote:
> Can’t you do something like weld the plates together to remove the
> clutch part of the front 103 Vairo so it only used the clutch pulley? I
> think that would be interesting.
yeah you could modify it to always be engaged. you could get rid of the balls and save some weight on the crank.
Andy - My instinct was to guess you were slipping too much, but it really sound like you maybe aren't slipping enough? I would put a tach on it and see where the clutch is hitting relative to your powerband.
or eliminate some variables (like the crank clutch) and tune the doppler and see how it feels. I lightened my shoes and made stiffer springs to get a higher rev engagement.
final drive ratios would be a factor too.
  Moby vs 103 50cc’s: your thoughts?Topic by: Toledo Riot Toledo Riot 02/27/20 04:08PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: jumpsuit steve jumpsuit steve 02/27/20 04:51PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Toledo Riot Toledo Riot 02/27/20 05:15PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Totally normal JBOT Totally normal JBOT 02/27/20 05:10PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Toledo Riot Toledo Riot 02/27/20 05:18PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: EH FCC of the QCB EH FCC of the QCB 02/27/20 09:08PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: jumpsuit steve jumpsuit steve 02/27/20 11:48PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Toledo Riot Toledo Riot 02/28/20 12:07PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Totally normal JBOT Totally normal JBOT 02/28/20 12:32PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Travis King Travis King 02/28/20 10:42PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Totally normal JBOT Totally normal JBOT 02/28/20 11:38PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Travis King Travis King 02/28/20 10:47PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Toledo Riot Toledo Riot 02/29/20 12:28AM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Toledo Riot Toledo Riot 03/01/20 02:03PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Totally normal JBOT Totally normal JBOT 03/01/20 02:47PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Daniel '' Daniel '' 03/01/20 06:11PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Graham Motzing Graham Motzing 03/02/20 12:58PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Toledo Riot Toledo Riot 03/02/20 02:11PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Toledo Riot Toledo Riot 03/02/20 12:54PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Totally normal JBOT Totally normal JBOT 03/02/20 01:31PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Daniel '' Daniel '' 03/02/20 03:04PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Toledo Riot Toledo Riot 03/02/20 03:50PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Toledo Riot Toledo Riot 03/04/20 11:27PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Daniel '' Daniel '' 03/05/20 02:19AM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Toledo Riot Toledo Riot 03/05/20 09:50AM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Daniel '' Daniel '' 03/05/20 09:53PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Toledo Riot Toledo Riot 03/06/20 09:27AM
  Re: Moby vs 103 50cc’s: your thoughts?Re: The Real Mike D The Real Mike D 03/06/20 10:26AM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Daniel '' Daniel '' 03/06/20 02:27PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: The Real Mike D The Real Mike D 03/06/20 04:59PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Toledo Riot Toledo Riot 03/06/20 05:13PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Zach Riddle Zach Riddle 03/08/20 11:19AM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Daniel '' Daniel '' 03/08/20 01:52PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Zach Riddle Zach Riddle 03/08/20 07:42PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Daniel '' Daniel '' 03/08/20 08:23PM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Toledo Riot Toledo Riot 03/09/20 11:11AM
  Re: Moby vs 103 50cc’s: your thoughts?Re: Toledo Riot Toledo Riot 03/13/20 09:51AM
