^ this
the other factor is slide cutaway, the amount of bevel on the bottom of the slide
a flat-bottom slide will be the richest low-part throttle, the more slanted bottoms are more progressive.
its pretty easy to mod them with a file or a sander to change, even a dremel round sanding drum will let you add a curve and get weird.
