Re: Wheel alignment
Aaron Goldman /
> baird co Wrote:
> > Aaron Goldman Wrote:
> > > baird co Wrote:
> > > Check the sprocket by spinning the wheel and holding a pencil,
> > > screwdriver, stick, whatever, right above the teeth. As it spins,
> > check
> > > the gap between the teeth and the stick.
> > > You'll notice if it hops up and down.
> > > But that wouldn't make your wheel hop. It'll just mess with your
> chain
> > > tension. And they all have a little bit of out of round-ness.
> > > It's the wheel or tire that would make it hop. Or a severely bent
> > axle.
> > I can tell you, for fact, if your wheels are out of round enough like
> > mine were it will absolutely move you up and down like a hopping,
> > galloping horse.
> > The wheel won't leave the ground but it absolutely makes you feel like
> > you're bobbing.
> That's not what I typed. Having a sprocket out of round a little bit
> But a flatspotted, or bent, or egg-shaped wheel would definitely give
> you a hoppity horse ride.
Apologies, definitely didn’t read your post right the first time.
  Wheel alignmentTopic by: Carraig Butler Carraig Butler 02/25/20 11:57AM
  Re: Wheel alignmentRe: P D P D 02/25/20 12:04PM
  Re: Wheel alignmentRe: Carraig Butler Carraig Butler 02/25/20 12:39PM
  Re: Wheel alignmentRe: baird co baird co 02/25/20 12:22PM
  Re: Wheel alignmentRe: Carraig Butler Carraig Butler 02/25/20 12:37PM
  Re: Wheel alignmentRe: live ɘvil live ɘvil 02/25/20 12:49PM
  Re: Wheel alignmentRe: Probably Fred Probably Fred 02/25/20 02:18PM
  Re: Wheel alignmentRe: FUCKN JBOT FUCKN JBOT 02/25/20 03:11PM
  Re: Wheel alignmentRe: Carraig Butler Carraig Butler 02/26/20 11:40AM
  Re: Wheel alignmentRe: FUCKN JBOT FUCKN JBOT 02/26/20 12:03PM
  Re: Wheel alignmentRe: Carraig Butler Carraig Butler 02/26/20 12:04PM
  Re: Wheel alignmentRe: FUCKN JBOT FUCKN JBOT 02/25/20 01:04PM
  Re: Wheel alignmentRe: Carraig Butler Carraig Butler 02/25/20 01:21PM
  Re: Wheel alignmentRe: FUCKN JBOT FUCKN JBOT 02/25/20 01:58PM
  Re: Wheel alignmentRe: Carraig Butler Carraig Butler 02/25/20 02:57PM
  Re: Wheel alignmentRe: Born to be WillD Born to be WillD 03/05/20 10:31AM
  Re: Wheel alignmentRe: Carraig Butler Carraig Butler 03/05/20 10:42AM
  Re: Wheel alignmentRe: Aaron Goldman Aaron Goldman 03/05/20 11:02AM
  Re: Wheel alignmentRe: baird co baird co 03/06/20 10:00AM
  Re: Wheel alignmentRe: Aaron Goldman Aaron Goldman 03/06/20 11:05AM
  Re: Wheel alignmentRe: baird co baird co 03/07/20 12:10AM
  Re: Wheel alignmentRe: Aaron Goldman Aaron Goldman 03/07/20 05:40AM
