Re: A3 Kit weird question
Dirty30 Dillon /
You'll have to check bore tolerance, ring gap and squish, as those are all things that will be different even between the same cylinder amongst different castings.
45mm is nominal sizing, so just be sure the piston to bore is within spec and check your squish after assembling
