Re: Puch rear sprocket
Adam Smith /
> up shits creek Wrote:
> I'm in the same boat. currently my mag does 41 top speed on stock gears.
> 70cc treats v1 kit - (i believe no porting - no case match - haven't
> opened it up), 15mm bing(76jet), stock crank, circuit pipe, dunno bout
> clutch, high flow air filter
> got 17t front,40t and 36t rears coming from treats. i'd also like to top
> out at about that 50ish but fear the stock crank - so i'm trying to keep
> it at or under 9k rpm (16x36 is what i'm going to try first)
Case March would likely help you!
