Re: Kreidler mp-19 15mm carb upgrade a mistake? Can’t keep it running.
Beach Club Nick /
> Lucs :) Wrote:
> I’ve been messing with different jets, I’ve tried everything between
> 78-82. The idle screw is pretty much all the way in could maybe turn
> another 1/8 turn.
> When I can get it to start and run long enough to ride it a bit, it
> won’t go over 26mph, which is pretty much where it was before I swapped
> the stock carb and pipe.
It sounds to me like your jetting is just off. You 78-82 isn't that large of a range to try. You said you can ride it occasionally; what's the plug look like? The plug will tell you what you need to do to the jetting. Look up Plug Chop on the wiki if you're not familiar. You don't have to hacksaw off the threads or anything, just get a good reading on the plug
