vespa cdi flywheel
Can use the cdi flywheel from the vespa cdi on the kinetic cdi? If so using the woodruff key it would timed already on vespa cases.
Re: vespa cdi flywheel
Can I use sorry missed a letter
I don't think you can. You can take a kinetic cdi and put it on a vespa with points cases, but not on vespa cdi cases.
points cases, kinetic cdi but with a vespa cdi flywheel
Dirty30 Dillon /
No, you can not.
thanks
