Re: 50/50
Graham Motzing /
> Dr No Fun Wrote:
> Get yourself a piece of sheet metal about 3 mm thick put it under the
> cylinder with a gasket on each side.
> After completing the above you will need to trim off the top of the
> cylinder so you have a squash of .8 mm 1.1mm at the outer edge of the
> piston.
this whole post is good stuff, i dunno if its minarelli specific or what... but this part is really tough for most people in home shops, the v1 has that stepped sealing area on the head that makes it really tough to cut down, especially 3 mm.
my general 5 star had an evracing pipe (basically a tecno bullet), a 15mm bing, and very very mild porting, went 40 + with stock gearing and trucked, probably could have been 45 with taller gears. You don't have to mess with lathes and spacers and all that, but the specs (165 exhaust/ 135 intake) are kinda the max for stock cylinders without loosing a bunch of low end.
I don't really port transfers on stock cylinders much, that might be the difference between 45 and 50 mph bikes, it just seems like a lot more work than its worth unless you just want to be able to say you did it. All the single speed 50/50 bikes i've ridden have been pretty doggy off the line. I like my 45 mph stockers that rip hard off the line.
Believe it or not, the guys that designed these did actually know what they were doing, they were just targeting reliability, torque, and a 30 mph max speed. It takes surprisingly little porting to wake them up.
  50/50Topic by: Trent Anderson Trent Anderson 02/07/20 09:38PM
  Re: 50/50Re: Dickie Gila Dickie Gila 02/07/20 10:02PM
  Re: 50/50Re: Marc Alan Marc Alan 03/26/20 11:02PM
  Re: 50/50Re: Toledo Riot Toledo Riot 03/27/20 12:03AM
  Re: 50/50Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 03/27/20 07:32AM
  Re: 50/50Re: Dr No Fun Dr No Fun 03/27/20 03:15PM
  Re: 50/50Re: Daniel '' Daniel '' 05/03/20 12:44PM
  Re: 50/50Re: Emil Kniemel Emil Kniemel 05/03/20 01:46PM
  Re: 50/50Re: Daniel '' Daniel '' 05/03/20 08:16PM
  Re: 50/50Re: Emil Kniemel Emil Kniemel 05/04/20 01:39AM
  Re: 50/50Re: Probably Fred Probably Fred 02/08/20 02:25AM
  Re: 50/50Re: Totally normal JBOT Totally normal JBOT 02/08/20 02:35AM
  Re: 50/50Re: Trent Anderson Trent Anderson 02/08/20 01:20PM
  Re: 50/50Re: Richard Eberline Richard Eberline 02/09/20 07:58PM
  Re: 50/50Re: baird co baird co 02/10/20 12:56PM
  Re: 50/50Re: Born to be WillD Born to be WillD 02/18/20 03:59PM
  Re: 50/50Re: * * * * 02/18/20 05:00PM
  Re: 50/50Re: EH 📣FCC of the QCB EH 📣FCC of the QCB 03/24/20 08:05PM
  Re: 50/50Re: Born to be WillD Born to be WillD 02/18/20 04:16PM
  Re: 50/50Re: Zach Riddle Zach Riddle 02/20/20 02:44PM
  Re: 50/50Re: Emil Kniemel Emil Kniemel 03/22/20 01:32AM
  Re: 50/50Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 03/22/20 09:14AM
  Re: 50/50Re: Emil Kniemel Emil Kniemel 03/22/20 12:52PM
  Re: 50/50Re: Max (ツ) Max (ツ) 03/22/20 02:17PM
  Re: 50/50Re: Emil Kniemel Emil Kniemel 03/22/20 04:41PM
  Re: 50/50Re: â—• ‿ â—• â—• ‿ â—• 05/03/20 08:20PM
  Re: 50/50Re: baird co baird co 05/03/20 10:45PM
  Re: 50/50Re: Rebel Moby Rebel Moby 03/22/20 01:15PM
  Re: 50/50Re: pat splat pat splat 03/22/20 02:17PM
  Re: 50/50Re: Dr No Fun Dr No Fun 03/24/20 02:52PM
  Re: 50/50Re: Graham Motzing Graham Motzing 03/24/20 03:32PM
  Re: 50/50Re: Dr No Fun Dr No Fun 03/24/20 03:41PM
  Re: 50/50Re: Graham Motzing Graham Motzing 03/24/20 09:27PM
  Re: 50/50Re: EH 📣FCC of the QCB EH 📣FCC of the QCB 03/25/20 10:20AM
  Re: 50/50Re: Dirty30 Dillon Dirty30 Dillon 03/25/20 01:13PM
  Re: 50/50Re: Dr No Fun Dr No Fun 03/25/20 01:43PM
  Re: 50/50Re: Max (ツ) Max (ツ) 03/27/20 07:00AM
  Re: 50/50Re: Born to be WillD Born to be WillD 03/27/20 10:25AM
  Re: 50/50Re: baird co baird co 03/25/20 01:18AM
  Re: 50/50Re: Dr No Fun Dr No Fun 03/25/20 08:13AM
  Re: 50/50Re: Graham Motzing Graham Motzing 03/25/20 10:51AM
  Re: 50/50Re: Dirty30 Dillon Dirty30 Dillon 03/24/20 03:49PM
  Re: 50/50Re: Graham Motzing Graham Motzing 03/25/20 11:11AM
  Re: 50/50Re: Toledo Riot Toledo Riot 03/27/20 01:52PM
  Re: 50/50Re: Emil Kniemel Emil Kniemel 04/19/20 04:17PM
  Re: 50/50Re: Dr No Fun Dr No Fun 04/19/20 06:50PM
  Re: 50/50Re: Emil Kniemel Emil Kniemel 04/26/20 06:46PM
  Re: 50/50Re: Trent Anderson Trent Anderson 05/03/20 12:36AM
  Re: 50/50Re: Jay Rivett Jay Rivett 05/03/20 02:45AM
