No. You can’t remove your stock spring and substitute the polini spring. It is weaker than the stock spring and will not work unless it’s used in conjunction with the stock spring.
Subject | Written By | Posted |
Peugeot polini spring setup fit with stock pipe?Topic by: kevin - | kevin - | 02/04/20 07:19PM |
Re: Peugeot polini spring setup fit with stock pipe?Re: Daniel '' | Daniel '' | 02/04/20 08:50PM |
Re: Peugeot polini spring setup fit with stock pipe?Re: kevin - | kevin - | 02/05/20 01:06PM |
Re: Peugeot polini spring setup fit with stock pipe?Re: Daniel '' | Daniel '' | 02/06/20 02:35AM |
Re: Peugeot polini spring setup fit with stock pipe?Re: kevin - | kevin - | 02/06/20 09:20PM |
