Clutchless means no idle and you have to tune it well since there is no clutch to compensate for sloppy low speed tuning.
Advantages include less rotating mass which means more top end and faster acceleration in some situations.
Belt wear is the same unless you are using a launch lever to slip the belt, in which case idk, more wear over time I guess?
