Re: Mikuni 20mm Carb setup help
ricky miles /
SOLVED...it was a huge air leak. I had pushed the stator side seal in too far and it caused a gap in-between the seal and the case. Fixed it and now carbi tuning is normal. Thanks to all that suggested to check for an air leak! Was a huge pain in the ass to fix. I had to completely disassemble the engine to get the seal out. Thanks again all!
ricky
  Mikuni 20mm Carb setup helpTopic by: ricky miles ricky miles 01/29/20 09:50PM
  Re: Mikuni 20mm Carb setup helpRe: D dB D dB 01/29/20 10:52PM
  Re: Mikuni 20mm Carb setup helpRe: D dB D dB 01/29/20 11:05PM
  Re: Mikuni 20mm Carb setup helpRe: ricky miles ricky miles 01/29/20 11:11PM
  Re: Mikuni 20mm Carb setup helpRe: Aaron Blair Aaron Blair 01/29/20 11:23PM
  Re: Mikuni 20mm Carb setup helpRe: ricky miles ricky miles 01/29/20 11:29PM
  Re: Mikuni 20mm Carb setup helpRe: Aaron Blair Aaron Blair 01/29/20 11:32PM
  Re: Mikuni 20mm Carb setup helpRe: ricky miles ricky miles 01/29/20 11:57PM
  Re: Mikuni 20mm Carb setup helpRe: ricky miles ricky miles 01/30/20 12:05AM
  Re: Mikuni 20mm Carb setup helpRe: pat splat pat splat 01/30/20 01:10AM
  Re: Mikuni 20mm Carb setup helpRe: Aaron Blair Aaron Blair 01/30/20 03:22AM
  Re: Mikuni 20mm Carb setup helpRe: - bart - bart 01/30/20 06:59AM
  Re: Mikuni 20mm Carb setup helpRe: ken gilbert ken gilbert 01/30/20 08:31AM
  Re: Mikuni 20mm Carb setup helpRe: Aaron Blair Aaron Blair 01/30/20 08:40AM
  Re: Mikuni 20mm Carb setup helpRe: Alex hernandez Alex hernandez 01/30/20 09:01AM
  Re: Mikuni 20mm Carb setup helpRe: Will I am Will I am 01/30/20 09:11AM
  Re: Mikuni 20mm Carb setup helpRe: Dirty30 Dillon Dirty30 Dillon 01/30/20 09:20AM
  Re: Mikuni 20mm Carb setup helpRe: Will I am Will I am 01/30/20 11:39AM
  Re: Mikuni 20mm Carb setup helpRe: Dirty30 Dillon Dirty30 Dillon 01/30/20 11:46AM
  Re: Mikuni 20mm Carb setup helpRe: Will I am Will I am 01/30/20 12:02PM
  Re: Mikuni 20mm Carb setup helpRe: ricky miles ricky miles 01/30/20 03:05PM
  Re: Mikuni 20mm Carb setup helpRe: P D P D 01/30/20 03:15PM
  Re: Mikuni 20mm Carb setup helpRe: ken gilbert ken gilbert 01/30/20 04:01PM
  Re: Mikuni 20mm Carb setup helpRe: Will I am Will I am 01/30/20 03:08PM
  Re: Mikuni 20mm Carb setup helpRe: P D P D 01/30/20 04:37PM
  Re: Mikuni 20mm Carb setup helpRe: Will I am Will I am 01/30/20 05:24PM
  Re: Mikuni 20mm Carb setup helpRe: Dirty30 Dillon Dirty30 Dillon 01/30/20 05:26PM
  Re: Mikuni 20mm Carb setup helpRe: ricky miles ricky miles 01/30/20 06:54PM
  Re: Mikuni 20mm Carb setup helpRe: ricky miles ricky miles 03/12/20 02:21PM
  Re: Mikuni 20mm Carb setup helpRe: Tomos A35 Tomos A35 01/30/20 07:05PM
  Re: Mikuni 20mm Carb setup helpRe: Pushrod Fifty Pushrod Fifty 03/12/20 03:08PM
