Re: Mikuni 20mm Carb setup help
P D /
> Will I am Wrote:
> Buy a can of carb cleaner and spray all seals, carb, cylinder,
> intake....when it starts to die out you found your leak.
NEVER buy, let alone use , carb cleaner .
It eats rubber and rubber type materials . But , go ahead and shorten the life of your seals and such . The vendors love that and you really need the practice of tearing your motor apart .
If you want to clean a carb use brake cleaner . It cleans better , quicker , leaves no residue and doesn't destroy rubber .
If you need to find a cylinder leak , try a propane torch , opened on low and unlit .
If there's a leak , the motor will notify you , immediately , without any damage .
  Mikuni 20mm Carb setup helpTopic by: ricky miles ricky miles 01/29/20 09:50PM
  Re: Mikuni 20mm Carb setup helpRe: D dB D dB 01/29/20 10:52PM
  Re: Mikuni 20mm Carb setup helpRe: D dB D dB 01/29/20 11:05PM
  Re: Mikuni 20mm Carb setup helpRe: ricky miles ricky miles 01/29/20 11:11PM
  Re: Mikuni 20mm Carb setup helpRe: Aaron Blair Aaron Blair 01/29/20 11:23PM
  Re: Mikuni 20mm Carb setup helpRe: ricky miles ricky miles 01/29/20 11:29PM
  Re: Mikuni 20mm Carb setup helpRe: Aaron Blair Aaron Blair 01/29/20 11:32PM
  Re: Mikuni 20mm Carb setup helpRe: ricky miles ricky miles 01/29/20 11:57PM
  Re: Mikuni 20mm Carb setup helpRe: ricky miles ricky miles 01/30/20 12:05AM
  Re: Mikuni 20mm Carb setup helpRe: pat splat pat splat 01/30/20 01:10AM
  Re: Mikuni 20mm Carb setup helpRe: Aaron Blair Aaron Blair 01/30/20 03:22AM
  Re: Mikuni 20mm Carb setup helpRe: - bart - bart 01/30/20 06:59AM
  Re: Mikuni 20mm Carb setup helpRe: ken gilbert ken gilbert 01/30/20 08:31AM
  Re: Mikuni 20mm Carb setup helpRe: Aaron Blair Aaron Blair 01/30/20 08:40AM
  Re: Mikuni 20mm Carb setup helpRe: Alex hernandez Alex hernandez 01/30/20 09:01AM
  Re: Mikuni 20mm Carb setup helpRe: Will I am Will I am 01/30/20 09:11AM
  Re: Mikuni 20mm Carb setup helpRe: Dirty30 Dillon Dirty30 Dillon 01/30/20 09:20AM
  Re: Mikuni 20mm Carb setup helpRe: Will I am Will I am 01/30/20 11:39AM
  Re: Mikuni 20mm Carb setup helpRe: Dirty30 Dillon Dirty30 Dillon 01/30/20 11:46AM
  Re: Mikuni 20mm Carb setup helpRe: Will I am Will I am 01/30/20 12:02PM
  Re: Mikuni 20mm Carb setup helpRe: ricky miles ricky miles 01/30/20 03:05PM
  Re: Mikuni 20mm Carb setup helpRe: P D P D 01/30/20 03:15PM
  Re: Mikuni 20mm Carb setup helpRe: ken gilbert ken gilbert 01/30/20 04:01PM
  Re: Mikuni 20mm Carb setup helpRe: Will I am Will I am 01/30/20 03:08PM
  Re: Mikuni 20mm Carb setup helpRe: P D P D 01/30/20 04:37PM
  Re: Mikuni 20mm Carb setup helpRe: Will I am Will I am 01/30/20 05:24PM
  Re: Mikuni 20mm Carb setup helpRe: Dirty30 Dillon Dirty30 Dillon 01/30/20 05:26PM
  Re: Mikuni 20mm Carb setup helpRe: ricky miles ricky miles 01/30/20 06:54PM
  Re: Mikuni 20mm Carb setup helpRe: ricky miles ricky miles 03/12/20 02:21PM
  Re: Mikuni 20mm Carb setup helpRe: Tomos A35 Tomos A35 01/30/20 07:05PM
  Re: Mikuni 20mm Carb setup helpRe: Pushrod Fifty Pushrod Fifty 03/12/20 03:08PM
