Re: Mikuni 20mm Carb setup help
ricky miles /
Hi all and thanks for the responses,
Ill order a set of jets today so that I can experiment. And ill order a temp gauge.
As far as an air leak... I cant imagine where the leak would be i build the engine last week and everything is to torque specs and all the seals and gaskets are new. i guess the only real way to check for air leaks w/in the engine case is to use a compression tool?
Id like to verify im running a 180 because like Dirty30 said, running with choke on is a symptom of running lean right? so with a 180 i should be far from lean. Is there a way to check and be sure im running a 180? is it written on the jet?
Does the wrong size jet commonly cause the bike to run only when the choke is on? or is that uncommon?
when you google "wont run without choke" everyone says its a blocked pilot jet. since my carb is new that cant be but maybe i need to adjust the pilot jet? is that an option? like i said im new to the art of carbs and jets.
Thanks for all the help.
  Mikuni 20mm Carb setup helpTopic by: ricky miles ricky miles 01/29/20 09:50PM
  Re: Mikuni 20mm Carb setup helpRe: D dB D dB 01/29/20 10:52PM
  Re: Mikuni 20mm Carb setup helpRe: D dB D dB 01/29/20 11:05PM
  Re: Mikuni 20mm Carb setup helpRe: ricky miles ricky miles 01/29/20 11:11PM
  Re: Mikuni 20mm Carb setup helpRe: Aaron Blair Aaron Blair 01/29/20 11:23PM
  Re: Mikuni 20mm Carb setup helpRe: ricky miles ricky miles 01/29/20 11:29PM
  Re: Mikuni 20mm Carb setup helpRe: Aaron Blair Aaron Blair 01/29/20 11:32PM
  Re: Mikuni 20mm Carb setup helpRe: ricky miles ricky miles 01/29/20 11:57PM
  Re: Mikuni 20mm Carb setup helpRe: ricky miles ricky miles 01/30/20 12:05AM
  Re: Mikuni 20mm Carb setup helpRe: pat splat pat splat 01/30/20 01:10AM
  Re: Mikuni 20mm Carb setup helpRe: Aaron Blair Aaron Blair 01/30/20 03:22AM
  Re: Mikuni 20mm Carb setup helpRe: - bart - bart 01/30/20 06:59AM
  Re: Mikuni 20mm Carb setup helpRe: ken gilbert ken gilbert 01/30/20 08:31AM
  Re: Mikuni 20mm Carb setup helpRe: Aaron Blair Aaron Blair 01/30/20 08:40AM
  Re: Mikuni 20mm Carb setup helpRe: Alex hernandez Alex hernandez 01/30/20 09:01AM
  Re: Mikuni 20mm Carb setup helpRe: Will I am Will I am 01/30/20 09:11AM
  Re: Mikuni 20mm Carb setup helpRe: Dirty30 Dillon Dirty30 Dillon 01/30/20 09:20AM
  Re: Mikuni 20mm Carb setup helpRe: Will I am Will I am 01/30/20 11:39AM
  Re: Mikuni 20mm Carb setup helpRe: Dirty30 Dillon Dirty30 Dillon 01/30/20 11:46AM
  Re: Mikuni 20mm Carb setup helpRe: Will I am Will I am 01/30/20 12:02PM
  Re: Mikuni 20mm Carb setup helpRe: ricky miles ricky miles 01/30/20 03:05PM
  Re: Mikuni 20mm Carb setup helpRe: P D P D 01/30/20 03:15PM
  Re: Mikuni 20mm Carb setup helpRe: ken gilbert ken gilbert 01/30/20 04:01PM
  Re: Mikuni 20mm Carb setup helpRe: Will I am Will I am 01/30/20 03:08PM
  Re: Mikuni 20mm Carb setup helpRe: P D P D 01/30/20 04:37PM
  Re: Mikuni 20mm Carb setup helpRe: Will I am Will I am 01/30/20 05:24PM
  Re: Mikuni 20mm Carb setup helpRe: Dirty30 Dillon Dirty30 Dillon 01/30/20 05:26PM
  Re: Mikuni 20mm Carb setup helpRe: ricky miles ricky miles 01/30/20 06:54PM
  Re: Mikuni 20mm Carb setup helpRe: ricky miles ricky miles 03/12/20 02:21PM
  Re: Mikuni 20mm Carb setup helpRe: Tomos A35 Tomos A35 01/30/20 07:05PM
  Re: Mikuni 20mm Carb setup helpRe: Pushrod Fifty Pushrod Fifty 03/12/20 03:08PM
