Re: Mikuni 20mm Carb setup help
Dirty30 Dillon /
> Will I am Wrote:
> What do you think the con of the dial jet is?
The biggest downsize is you have no frame of reference for what size jet you are running. The dial-a-jet is not indexed, so you have no way of knowing what orifice size you are actually getting.
That, and all it takes is someone or something rotating that screw on you, or vibrations turning it and you could fuck yourself. even if you don't seize, you have to go through the whole process of turning and tuning again. I would much rather have a hard jet that I can properly clean and replace without re-tuning every time.
  Mikuni 20mm Carb setup helpTopic by: ricky miles ricky miles 01/29/20 09:50PM
  Re: Mikuni 20mm Carb setup helpRe: D dB D dB 01/29/20 10:52PM
  Re: Mikuni 20mm Carb setup helpRe: D dB D dB 01/29/20 11:05PM
  Re: Mikuni 20mm Carb setup helpRe: ricky miles ricky miles 01/29/20 11:11PM
  Re: Mikuni 20mm Carb setup helpRe: Aaron Blair Aaron Blair 01/29/20 11:23PM
  Re: Mikuni 20mm Carb setup helpRe: ricky miles ricky miles 01/29/20 11:29PM
  Re: Mikuni 20mm Carb setup helpRe: Aaron Blair Aaron Blair 01/29/20 11:32PM
  Re: Mikuni 20mm Carb setup helpRe: ricky miles ricky miles 01/29/20 11:57PM
  Re: Mikuni 20mm Carb setup helpRe: ricky miles ricky miles 01/30/20 12:05AM
  Re: Mikuni 20mm Carb setup helpRe: pat splat pat splat 01/30/20 01:10AM
  Re: Mikuni 20mm Carb setup helpRe: Aaron Blair Aaron Blair 01/30/20 03:22AM
  Re: Mikuni 20mm Carb setup helpRe: - bart - bart 01/30/20 06:59AM
  Re: Mikuni 20mm Carb setup helpRe: ken gilbert ken gilbert 01/30/20 08:31AM
  Re: Mikuni 20mm Carb setup helpRe: Aaron Blair Aaron Blair 01/30/20 08:40AM
  Re: Mikuni 20mm Carb setup helpRe: Alex hernandez Alex hernandez 01/30/20 09:01AM
  Re: Mikuni 20mm Carb setup helpRe: Will I am Will I am 01/30/20 09:11AM
  Re: Mikuni 20mm Carb setup helpRe: Dirty30 Dillon Dirty30 Dillon 01/30/20 09:20AM
  Re: Mikuni 20mm Carb setup helpRe: Will I am Will I am 01/30/20 11:39AM
  Re: Mikuni 20mm Carb setup helpRe: Dirty30 Dillon Dirty30 Dillon 01/30/20 11:46AM
  Re: Mikuni 20mm Carb setup helpRe: Will I am Will I am 01/30/20 12:02PM
  Re: Mikuni 20mm Carb setup helpRe: ricky miles ricky miles 01/30/20 03:05PM
  Re: Mikuni 20mm Carb setup helpRe: P D P D 01/30/20 03:15PM
  Re: Mikuni 20mm Carb setup helpRe: ken gilbert ken gilbert 01/30/20 04:01PM
  Re: Mikuni 20mm Carb setup helpRe: Will I am Will I am 01/30/20 03:08PM
  Re: Mikuni 20mm Carb setup helpRe: P D P D 01/30/20 04:37PM
  Re: Mikuni 20mm Carb setup helpRe: Will I am Will I am 01/30/20 05:24PM
  Re: Mikuni 20mm Carb setup helpRe: Dirty30 Dillon Dirty30 Dillon 01/30/20 05:26PM
  Re: Mikuni 20mm Carb setup helpRe: ricky miles ricky miles 01/30/20 06:54PM
  Re: Mikuni 20mm Carb setup helpRe: ricky miles ricky miles 03/12/20 02:21PM
  Re: Mikuni 20mm Carb setup helpRe: Tomos A35 Tomos A35 01/30/20 07:05PM
  Re: Mikuni 20mm Carb setup helpRe: Pushrod Fifty Pushrod Fifty 03/12/20 03:08PM
