Re: Racing crank for Kinetic
Graham Motzing /
i'm pretty sure you gotta buy a vespa clutch or at least the vespa hub to go on a non-kinetic crank.
the kinetic crank has better timing than a stock vespa crank... its already 'cut' so to speak so they actually perform really well with a slap-on kit.
if you want to do a slap-on you are probably better off with the malossi because it comes with a head and i don't think the DR will run that much better than a malossi on a stock bottom end but who knows, vespas are a fuckin mystery.
