Re: Racing crank for Kinetic
- Joe - /
The stock crank should be fine with a dr kit. I used that mazzy crank in my kinetic when I built it, but I also swapped to a variated setup when I did the kit/rebuild. My kinetic crank had a longer threaded portion to hold the clutch on vs the mazzy crank. I’m not sure if my clutch would have worked with it. It may work fine just giving you the heads up.
