did it pull better with the stock exhaust?
Maybe there is a restrictor washer in the header of your new pipe that you didn't remove
maybe your belt is loose and when you rev from a stop, it shifts the vario into high gear and slips the clutch
you can only do one of the crank seals without splitting the cases.
