Re: Peugeot 104/103 Airsal 70cc kit
> Carraig Butler Wrote:
> Do you think that it could be that the crank case seal is bad and it’s
> not getting the fuel it needs and the old cylinder is working because it
> doesn’t require as much fuel?
Nope , if you had a bad seal all the cylinders would pretty much act the same and just not run correctly.
Your cylinder is done it sounds like. Now before you go spending anymore money I was highly recommend some more reading. 150miles is not anything (even with a cheap chines eBay kit) you should be seeing Atleast 1,000miles ( piston ring swap at 500miles).
I’m usually one for hard brake ins
  Peugeot 104/103 Airsal 70cc kitTopic by: Carraig Butler Carraig Butler 01/11/20 05:59PM
  Re: Peugeot 104/103 Airsal 70cc kitRe: * * * * 01/11/20 06:26PM
  Re: Peugeot 104/103 Airsal 70cc kitRe: Carraig Butler Carraig Butler 01/11/20 06:29PM
  Re: Peugeot 104/103 Airsal 70cc kitRe: * * * * 01/11/20 07:13PM
  Re: Peugeot 104/103 Airsal 70cc kitRe: Carraig Butler Carraig Butler 01/11/20 07:21PM
  Re: Peugeot 104/103 Airsal 70cc kitRe: Norris Hall Norris Hall 01/11/20 10:09PM
  Re: Peugeot 104/103 Airsal 70cc kitRe: Carraig Butler Carraig Butler 01/11/20 11:13PM
  Re: Peugeot 104/103 Airsal 70cc kitRe: * * * * 01/11/20 11:22PM
  Re: Peugeot 104/103 Airsal 70cc kitRe: pat splat pat splat 01/11/20 11:40PM
  Re: Peugeot 104/103 Airsal 70cc kitRe: jumpsuit steve jumpsuit steve 01/12/20 09:02AM
  Re: Peugeot 104/103 Airsal 70cc kitRe: Carraig Butler Carraig Butler 01/12/20 04:40PM
  Re: Peugeot 104/103 Airsal 70cc kitRe: jumpsuit steve jumpsuit steve 01/12/20 05:59PM
  Re: Peugeot 104/103 Airsal 70cc kitRe: Carraig Butler Carraig Butler 01/12/20 06:01PM
  Re: Peugeot 104/103 Airsal 70cc kitRe: Carraig Butler Carraig Butler 01/12/20 08:00PM
  Re: Peugeot 104/103 Airsal 70cc kitRe: jumpsuit steve jumpsuit steve 01/13/20 09:35AM
  Re: Peugeot 104/103 Airsal 70cc kitRe: * * * * 01/12/20 11:30PM
  Re: Peugeot 104/103 Airsal 70cc kitRe: Carraig Butler Carraig Butler 01/13/20 12:15AM
  Re: Peugeot 104/103 Airsal 70cc kitRe: * * * * 01/13/20 01:41AM
  Re: Peugeot 104/103 Airsal 70cc kitRe: Carraig Butler Carraig Butler 01/13/20 02:26AM
  Re: Peugeot 104/103 Airsal 70cc kitRe: Carraig Butler Carraig Butler 01/14/20 10:56AM
  Re: Peugeot 104/103 Airsal 70cc kitRe: * * * * 01/14/20 02:36PM
  Re: Peugeot 104/103 Airsal 70cc kitRe: Carraig Butler Carraig Butler 01/14/20 09:34PM
  Re: Peugeot 104/103 Airsal 70cc kitRe: * * * * 01/15/20 12:01AM
  Re: Peugeot 104/103 Airsal 70cc kitRe: Aaron Blair Aaron Blair 01/14/20 11:58PM
  Re: Peugeot 104/103 Airsal 70cc kitRe: Carraig Butler Carraig Butler 01/15/20 12:04AM
  Re: Peugeot 104/103 Airsal 70cc kitRe: Daniel '' Daniel '' 01/15/20 12:12AM
  Re: Peugeot 104/103 Airsal 70cc kitRe: Carraig Butler Carraig Butler 01/15/20 12:15AM
  Re: Peugeot 104/103 Airsal 70cc kitRe: Daniel '' Daniel '' 01/15/20 01:08PM
  Re: Peugeot 104/103 Airsal 70cc kitRe: Carraig Butler Carraig Butler 01/15/20 01:24PM
  Re: Peugeot 104/103 Airsal 70cc kitRe: Daniel '' Daniel '' 01/15/20 01:50PM
  Re: Peugeot 104/103 Airsal 70cc kitRe: Carraig Butler Carraig Butler 01/15/20 01:57PM
  Re: Peugeot 104/103 Airsal 70cc kitRe: Daniel '' Daniel '' 01/15/20 02:36PM
  Re: Peugeot 104/103 Airsal 70cc kitRe: Carraig Butler Carraig Butler 01/16/20 05:07PM
  Re: Peugeot 104/103 Airsal 70cc kitRe: Daniel '' Daniel '' 01/16/20 05:21PM
  Re: Peugeot 104/103 Airsal 70cc kitRe: Aaron Blair Aaron Blair 01/15/20 12:12AM
  Re: Peugeot 104/103 Airsal 70cc kitRe: Aaron Blair Aaron Blair 01/15/20 12:27AM
  Re: Peugeot 104/103 Airsal 70cc kitRe: Carraig Butler Carraig Butler 01/15/20 12:34AM
  Re: Peugeot 104/103 Airsal 70cc kitRe: Aaron Blair Aaron Blair 01/15/20 12:37AM
  Re: Peugeot 104/103 Airsal 70cc kitRe: Carraig Butler Carraig Butler 01/15/20 12:38AM
  Re: Peugeot 104/103 Airsal 70cc kitRe: * * * * 01/15/20 02:36AM
  Re: Peugeot 104/103 Airsal 70cc kitRe: jumpsuit steve jumpsuit steve 01/15/20 08:47AM
  Re: Peugeot 104/103 Airsal 70cc kitRe: P D P D 01/15/20 09:43AM
  Re: Peugeot 104/103 Airsal 70cc kitRe: Carraig Butler Carraig Butler 01/25/20 11:58PM
  Re: Peugeot 104/103 Airsal 70cc kitRe: Aaron Blair Aaron Blair 01/26/20 09:47PM
  Re: Peugeot 104/103 Airsal 70cc kitRe: Carraig Butler Carraig Butler 01/27/20 01:04PM
