Shaw Derbi
todd amundson /
Had to take this apart because the trans side bearing had the crank spinning inside of it. Lots of travel up and down, side to side. Of course the crank is toast because it wore a nice hyper race surface in itself. I knew this was Shaw's Derbi which is on its third owner. Wanted to take a few shots of what he did.
Daniel mentioned a crazy untunable cylinder recently that Shaw did. This is tunable I think but the intake window blows through the skirt a bit because it's giant. Has decomp hole drilled through it. Piston will hit decomp on start up and I think that crude divot was put in by the builder? I can't tell. Assembled without a gasket just yamabond. Lots of JB weld but only a little showing in the transfers. Crank had lube slot cut into small end. Aluminum base gasket with razor thin cereal box on either side. About 3 mm thick.
Re: Shaw Derbi
todd amundson /
There's a hole in the center of the photo.
Decomp added
I do this but have not done it with double ear clips
Re: Shaw Derbi
todd amundson /
Not sure which order but:
Go Derbi, Jesus Saves, Shaw
Re: Shaw Derbi
nice
Re: Shaw Derbi
Thanks for sharing! We have a Shaw 50/50 stock Puch cylinder that I have been meaning to do port-mapping and pictures for but have had no reason to pull the bike apart. One day. Bike is stupid fast with a 15SHA and bitturbo. It is nuts. And it has been running like that for 13? Years? Maybe more.
Re: Shaw Derbi
Wanna see that port map for sure
Re: Shaw Derbi
That intake is wild! Maybe I need to take another crack at that magnum jug...
Re: Shaw Derbi
RAD to see • Honest²
Re: Shaw Derbi
Kevin Bishop /
Is that a 1” pipe for an intake?
Re: Shaw Derbi
todd amundson /
no It’s metric so I’m pretty sure this is a 28mm header off something. The cool kicker is the decomp channel on the 47mm head is filled with maybe JB weld, then he ran the gases straight out the intake side of the jug rather than use the leaky trough out the exhaust.
Re: Shaw Derbi
If the decomp hole is plugged with JB Weld , there shouldn't be any gasses going anywhere , other than normal 2T flow .
Maybe he tried re-routing decomp gasses to the intake prior to plugging the decomp ?
Re: Shaw Derbi
PD it still has a hole it just realease compression to the intake instead of going allllllll the way around the stupid ring in the head.
Re: Shaw Derbi
OK .
That's the second post I miss-read today . I better go back to bed . :(
Re: Shaw Derbi
That’s brilliant. The main reason why I took the euro kit off my derbi is because it was near impossible to start with out a decomp.
Re: Shaw Derbi
Totally normal JBOT /
Starter shoes are the worst.
Pull start disc are the best
FUCK DECOMP
Re: Shaw Derbi
Id prefer to keep my pedals, but also a pull start would be cool?
Re: Shaw Derbi
Ed - Dead Possums /
Love to see his work. Being at Shaw's house I was a kid in a candy store! So much knowledge, and he loves to tell the stories of the good ol days.
Re: Shaw Derbi
Kevin Bishop /
Damn not far off from 1” probably 26mm ID then. Sounds like a seat post cutoff. I love repurposed parts.
