Re: Suggestions? on modifying bk100 pipe on Tomos
J Dubbs /
I have wrote my reply three times and it keeps disappearing... I'm not rushing my project and I had to bend my pipe to get the angle correct... Now I'm going to take it off and take photographs and show it and if I need it repaired I think it will be easier to repair now that the angle is right... I will remove my exhaust studs and replace them with new ones and put a thicker gasket on... This setup is nowhere ready to run yet.... I'm going to fabricate another intake using some old exhaust pipes.... I'm checking all my gaskets and using Indian Head sealer to make sure they're doing their job... If anyone has suggestions on finding air leaks other than using carburetor cleaner and listening for the higher revs I would appreciate it.... In the end I know it's a moped but it's my moped and I'm proud of it.... There's no way I'm leaving that mk kit sit on my shelf for the next 5 years and just talked about installing it... I'm going to file my jammer clutch shoes a little bit where the spring meets... And then double and triple check for air leaks again....
Either way I am making progress in a positive direction and it will be ready to be Ripppin on by the time spring is here.... I'm probably going to piss off a lot of neighbors and I'm sure it's going to be fun..
  Suggestions? on modifying bk100 pipe on TomosTopic by: J Dubbs J Dubbs 01/05/20 06:05PM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: pat splat pat splat 01/05/20 06:24PM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 01/05/20 08:34PM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: J Dubbs J Dubbs 01/05/20 09:04PM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: Ryan Graeme Ryan Graeme 01/06/20 12:09AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 01/06/20 07:02AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: J Dubbs J Dubbs 01/06/20 09:21AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: Dirty30 Dillon Dirty30 Dillon 01/06/20 10:45AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: J Dubbs J Dubbs 01/06/20 11:09AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: Totally normal JBOT Totally normal JBOT 01/06/20 02:24PM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: J Dubbs J Dubbs 01/06/20 11:11PM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: J Dubbs J Dubbs 01/06/20 11:15PM
  I modified bk100 Puch pipe on a Tomos and installed a 80cc Puch metriakitRe: J Dubbs J Dubbs 01/06/20 11:23PM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: Totally normal JBOT Totally normal JBOT 01/06/20 11:36PM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: J Dubbs J Dubbs 01/07/20 06:55AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: J Dubbs J Dubbs 01/07/20 07:27AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: Dirty30 Dillon Dirty30 Dillon 01/07/20 09:13AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: J Dubbs J Dubbs 01/07/20 10:10AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: Dirty30 Dillon Dirty30 Dillon 01/07/20 10:19AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: Bas Autowas Bas Autowas 01/07/20 10:37AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: P D P D 01/07/20 11:06AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: J Dubbs J Dubbs 01/07/20 11:22AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: Bas Autowas Bas Autowas 01/07/20 11:26AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 01/07/20 02:30PM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: Totally normal JBOT Totally normal JBOT 01/07/20 02:56PM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: Dirty30 Dillon Dirty30 Dillon 01/07/20 03:02PM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: J Dubbs J Dubbs 01/08/20 05:05AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: Ryan Graeme Ryan Graeme 01/07/20 12:12AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: ♣Slew Foot♣ ♣Slew Foot♣ 01/07/20 02:51AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: J Dubbs J Dubbs 01/07/20 06:23AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: Aaron Blair Aaron Blair 01/07/20 05:39AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: scrot rash scrot rash 01/07/20 09:05AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: Totally normal JBOT Totally normal JBOT 01/07/20 03:18PM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 01/07/20 07:26PM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: Totally normal JBOT Totally normal JBOT 01/07/20 09:03PM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: J Dubbs J Dubbs 01/08/20 04:56AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: J Dubbs J Dubbs 01/08/20 05:16AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: ♣Slew Foot♣ ♣Slew Foot♣ 01/08/20 08:07AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 01/08/20 10:56AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: J Dubbs J Dubbs 01/08/20 05:34AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: J Dubbs J Dubbs 01/08/20 05:41AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: J Dubbs J Dubbs 01/08/20 05:52AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 01/08/20 06:41AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: P D P D 01/08/20 09:10AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: ♣Slew Foot♣ ♣Slew Foot♣ 01/08/20 09:16AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: ♣Slew Foot♣ ♣Slew Foot♣ 01/08/20 08:18PM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: Tate G Tate G 01/08/20 12:43PM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: Totally normal JBOT Totally normal JBOT 01/08/20 12:47PM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: Max (ツ) Max (ツ) 02/03/20 06:12PM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: Dickie Gila Dickie Gila 02/03/20 10:42PM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: J Dubbs J Dubbs 02/04/20 05:52AM
