Re: Suggestions? on modifying bk100 pipe on Tomos
Totally normal JBOT /
Flexy rear frame mounts are the worst for header breakage. The header cracks like I think this one will, or if you're lucky enough to have it stay solid, the studs/exh screws will break off from even slight flex at the frame mount.
Spring mounted headers are the safest, but can leak if not done really well.
I've just seen lots of MLM header cracks even when no heating had been done and a solid rear frame mount,
I feel like pipe makers should use thicker header steel, I add a welded or brazed steel strap to the outside of some of my headers due to repeated breakages. Worst sound ever to hear when you're out far from home and you hear that distinctive header opening up "croak" then its louder and louder then its fucking awful (edited)
  Suggestions? on modifying bk100 pipe on TomosTopic by: J Dubbs J Dubbs 01/05/20 06:05PM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: pat splat pat splat 01/05/20 06:24PM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 01/05/20 08:34PM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: J Dubbs J Dubbs 01/05/20 09:04PM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: Ryan Graeme Ryan Graeme 01/06/20 12:09AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 01/06/20 07:02AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: J Dubbs J Dubbs 01/06/20 09:21AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: Dirty30 Dillon Dirty30 Dillon 01/06/20 10:45AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: J Dubbs J Dubbs 01/06/20 11:09AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: Totally normal JBOT Totally normal JBOT 01/06/20 02:24PM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: J Dubbs J Dubbs 01/06/20 11:11PM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: J Dubbs J Dubbs 01/06/20 11:15PM
  I modified bk100 Puch pipe on a Tomos and installed a 80cc Puch metriakitRe: J Dubbs J Dubbs 01/06/20 11:23PM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: Totally normal JBOT Totally normal JBOT 01/06/20 11:36PM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: J Dubbs J Dubbs 01/07/20 06:55AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: J Dubbs J Dubbs 01/07/20 07:27AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: Dirty30 Dillon Dirty30 Dillon 01/07/20 09:13AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: J Dubbs J Dubbs 01/07/20 10:10AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: Dirty30 Dillon Dirty30 Dillon 01/07/20 10:19AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: Bas Autowas Bas Autowas 01/07/20 10:37AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: P D P D 01/07/20 11:06AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: J Dubbs J Dubbs 01/07/20 11:22AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: Bas Autowas Bas Autowas 01/07/20 11:26AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 01/07/20 02:30PM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: Totally normal JBOT Totally normal JBOT 01/07/20 02:56PM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: Dirty30 Dillon Dirty30 Dillon 01/07/20 03:02PM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: J Dubbs J Dubbs 01/08/20 05:05AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: Ryan Graeme Ryan Graeme 01/07/20 12:12AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: ♣Slew Foot♣ ♣Slew Foot♣ 01/07/20 02:51AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: J Dubbs J Dubbs 01/07/20 06:23AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: Aaron Blair Aaron Blair 01/07/20 05:39AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: scuitar rex scuitar rex 01/07/20 09:05AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: Totally normal JBOT Totally normal JBOT 01/07/20 03:18PM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 01/07/20 07:26PM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: Totally normal JBOT Totally normal JBOT 01/07/20 09:03PM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: J Dubbs J Dubbs 01/08/20 04:56AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: J Dubbs J Dubbs 01/08/20 05:16AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: ♣Slew Foot♣ ♣Slew Foot♣ 01/08/20 08:07AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 01/08/20 10:56AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: J Dubbs J Dubbs 01/08/20 05:34AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: J Dubbs J Dubbs 01/08/20 05:41AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: J Dubbs J Dubbs 01/08/20 05:52AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 01/08/20 06:41AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: P D P D 01/08/20 09:10AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: ♣Slew Foot♣ ♣Slew Foot♣ 01/08/20 09:16AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: ♣Slew Foot♣ ♣Slew Foot♣ 01/08/20 08:18PM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: Tate G Tate G 01/08/20 12:43PM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: Totally normal JBOT Totally normal JBOT 01/08/20 12:47PM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: Max (ツ) Max (ツ) 02/03/20 06:12PM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: Dickie Gila Dickie Gila 02/03/20 10:42PM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: J Dubbs J Dubbs 02/04/20 05:52AM
