Re: Suggestions? on modifying bk100 pipe on Tomos
Is the kit a flat port? If so, treats sells a Cali pipe designed for puch flatport kits on tomos.
Is it angle port? If so, any tomos A55 pipe should bolt right up. Alternatively, a puch magnum pipe would at least have the correct angle, but it'd still be on the right side and mounting the rear securely would be trickier. No, don't bolt it to the swingarm.
If you want to do it the hard way with the pipe you currently have, I would heat and bend it in stages, along multiple points in the header. If you bend it all at once in one spot you'll flatten/collapse it. Now that you started the bike, the pipe may have oily exhaust residue inside that will make welding difficult, and it would already be somewhat difficult given the material nature.
Also, you should probably keep everything in one thread relevant to the bike as a whole. (edited)
  Suggestions? on modifying bk100 pipe on TomosTopic by: J Dubbs J Dubbs 01/05/20 06:05PM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: pat splat pat splat 01/05/20 06:24PM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 01/05/20 08:34PM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: J Dubbs J Dubbs 01/05/20 09:04PM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: Ryan Graeme Ryan Graeme 01/06/20 12:09AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 01/06/20 07:02AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: J Dubbs J Dubbs 01/06/20 09:21AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: Dirty30 Dillon Dirty30 Dillon 01/06/20 10:45AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: J Dubbs J Dubbs 01/06/20 11:09AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: Totally normal JBOT Totally normal JBOT 01/06/20 02:24PM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: J Dubbs J Dubbs 01/06/20 11:11PM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: J Dubbs J Dubbs 01/06/20 11:15PM
  I modified bk100 Puch pipe on a Tomos and installed a 80cc Puch metriakitRe: J Dubbs J Dubbs 01/06/20 11:23PM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: Totally normal JBOT Totally normal JBOT 01/06/20 11:36PM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: J Dubbs J Dubbs 01/07/20 06:55AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: J Dubbs J Dubbs 01/07/20 07:27AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: Dirty30 Dillon Dirty30 Dillon 01/07/20 09:13AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: J Dubbs J Dubbs 01/07/20 10:10AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: Dirty30 Dillon Dirty30 Dillon 01/07/20 10:19AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: Bas Autowas Bas Autowas 01/07/20 10:37AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: P D P D 01/07/20 11:06AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: J Dubbs J Dubbs 01/07/20 11:22AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: Bas Autowas Bas Autowas 01/07/20 11:26AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 01/07/20 02:30PM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: Totally normal JBOT Totally normal JBOT 01/07/20 02:56PM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: Dirty30 Dillon Dirty30 Dillon 01/07/20 03:02PM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: J Dubbs J Dubbs 01/08/20 05:05AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: Ryan Graeme Ryan Graeme 01/07/20 12:12AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: ♣Slew Foot♣ ♣Slew Foot♣ 01/07/20 02:51AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: J Dubbs J Dubbs 01/07/20 06:23AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: Aaron Blair Aaron Blair 01/07/20 05:39AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: scrot rash scrot rash 01/07/20 09:05AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: Totally normal JBOT Totally normal JBOT 01/07/20 03:18PM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 01/07/20 07:26PM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: Totally normal JBOT Totally normal JBOT 01/07/20 09:03PM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: J Dubbs J Dubbs 01/08/20 04:56AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: J Dubbs J Dubbs 01/08/20 05:16AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: ♣Slew Foot♣ ♣Slew Foot♣ 01/08/20 08:07AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 01/08/20 10:56AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: J Dubbs J Dubbs 01/08/20 05:34AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: J Dubbs J Dubbs 01/08/20 05:41AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: J Dubbs J Dubbs 01/08/20 05:52AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 01/08/20 06:41AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: P D P D 01/08/20 09:10AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: ♣Slew Foot♣ ♣Slew Foot♣ 01/08/20 09:16AM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: ♣Slew Foot♣ ♣Slew Foot♣ 01/08/20 08:18PM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: Tate G Tate G 01/08/20 12:43PM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: Totally normal JBOT Totally normal JBOT 01/08/20 12:47PM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: Max (ツ) Max (ツ) 02/03/20 06:12PM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: Dickie Gila Dickie Gila 02/03/20 10:42PM
  Re: Suggestions? on modifying bk100 pipe on TomosRe: J Dubbs J Dubbs 02/04/20 05:52AM
