Re: First time DR kit - Hobbit
Jack Rutherford /
Get a better head than the stock one.
Sport touring should run cooler. and "beware, you may need to cut a little bit of the fins to get the head to clear the frame/tank/petcock. be prepared! "
If you've never replaced a crank and bearings and you haven't already assembled the tools to do so then I would suggest replacing the seals and saving the crank and bearings for a later date. From there, swap in the reeds and new carb. Jet the carb for the stock engine and your exhaust. Once you've done that and it's running well, install the DR kit and re-jet the carb for that. I've seen too many people buy everything at once, install it all, and then be at a loss as to what went wrong.
I reread your post and you didn't get a bigger carb but a bigger carb jet. I'd go with a bigger than stock carb with that kit given it's propensity to generate lots of heat. (edited)
  First time DR kit - HobbitTopic by: BBD 83 BBD 83 01/03/20 09:01PM
  Re: First time DR kit - HobbitRe: Totally normal JBOT Totally normal JBOT 01/03/20 09:47PM
  Re: First time DR kit - HobbitRe: BBD 83 BBD 83 01/03/20 10:07PM
  Re: First time DR kit - HobbitRe: Totally normal JBOT Totally normal JBOT 01/03/20 10:21PM
  Re: First time DR kit - HobbitRe: Jack Rutherford Jack Rutherford 01/03/20 11:16PM
  Re: First time DR kit - HobbitRe: William Johnson William Johnson 01/06/20 02:20PM
  Re: First time DR kit - HobbitRe: BBD 83 BBD 83 01/08/20 11:12PM
  Re: First time DR kit - HobbitRe: Born to be WillD Born to be WillD 01/10/20 01:23PM
  Re: First time DR kit - HobbitRe: BBD 83 BBD 83 01/10/20 10:07PM
  Re: First time DR kit - HobbitRe: Born to be WillD Born to be WillD 01/06/20 02:46PM
  Re: First time DR kit - HobbitRe: BBD 83 BBD 83 01/08/20 11:24PM
  Re: First time DR kit - HobbitRe: Terbo Speghetti Terbo Speghetti 01/10/20 12:13PM
  Re: First time DR kit - HobbitRe: Kevin Bishop Kevin Bishop 01/10/20 07:28PM
  Re: First time DR kit - HobbitRe: BBD 83 BBD 83 01/10/20 10:08PM
  Re: First time DR kit - HobbitRe: Daniel '' Daniel '' 01/17/20 11:22PM
  Re: First time DR kit - HobbitRe: BBD 83 BBD 83 01/18/20 04:37PM
  Re: First time DR kit - HobbitRe: Born to be WillD Born to be WillD 01/20/20 10:00AM
  Re: First time DR kit - HobbitRe: Kevin Bishop Kevin Bishop 01/17/20 05:48PM
  Re: First time DR kit - HobbitRe: Chris . Chris . 01/17/20 07:55PM
  Re: First time DR kit - HobbitRe: Kevin Bishop Kevin Bishop 01/18/20 09:21PM
  Re: First time DR kit - HobbitRe: Daniel '' Daniel '' 01/18/20 10:30PM
  Re: First time DR kit - HobbitRe: Happy Pancake Happy Pancake 01/24/20 10:15PM
  Re: First time DR kit - HobbitRe: Kevin Bishop Kevin Bishop 01/24/20 06:06PM
  Re: First time DR kit - HobbitRe: Steve Paul Steve Paul 02/11/20 01:09PM
