Re: Diy reeds cut directly into Tomos case performance?
Totally normal JBOT /
Always.
Even cyl reed.
Cut the cyl reed for 360 deg intake and if you don't enlarge/raise the exh much it will still have excellent low blowdown for a very wide power band.
> niklaus _ Wrote:
> I would argue that a well tuned reed setup should outperform a piston
> port over a broad range of rpm, since the intake timing can be more
> aggressive
  Diy reeds cut directly into Tomos case performance?Topic by: J Dubbs J Dubbs 01/02/20 10:47AM
  Re: Diy reeds cut directly into Tomos case performance?Re: Dirty30 Dillon Dirty30 Dillon 01/02/20 10:53AM
  Re: Diy reeds cut directly into Tomos case performance?Re: Totally normal JBOT Totally normal JBOT 01/02/20 10:59AM
  Re: Diy reeds cut directly into Tomos case performance?Re: J Dubbs J Dubbs 01/02/20 12:23PM
  Re: Diy reeds cut directly into Tomos case performance?Re: Totally normal JBOT Totally normal JBOT 01/02/20 12:30PM
  Re: Diy reeds cut directly into Tomos case performance?Re: J Dubbs J Dubbs 01/02/20 11:25AM
  Re: Diy reeds cut directly into Tomos case performance?Re: Daniel '' Daniel '' 01/02/20 01:05PM
  Re: Diy reeds cut directly into Tomos case performance?Re: Daniel '' Daniel '' 01/02/20 11:17AM
  Re: Diy reeds cut directly into Tomos case performance?Re: EH 📣FCC of the QCB EH 📣FCC of the QCB 01/02/20 01:39PM
  Re: Diy reeds cut directly into Tomos case performance?Re: Totally normal JBOT Totally normal JBOT 01/02/20 01:43PM
  Re: Diy reeds cut directly into Tomos case performance?Re: Thomas TPRF Thomas TPRF 01/02/20 02:37PM
  Re: Diy reeds cut directly into Tomos case performance?Re: J Dubbs J Dubbs 01/02/20 01:54PM
  Re: Diy reeds cut directly into Tomos case performance?Re: Dirty30 Dillon Dirty30 Dillon 01/02/20 02:36PM
  Re: Diy reeds cut directly into Tomos case performance?Re: Cameron Cate Cameron Cate 01/02/20 04:50PM
  Re: Diy reeds cut directly into Tomos case performance?Re: Dirty30 Dillon Dirty30 Dillon 01/02/20 05:08PM
  Re: Diy reeds cut directly into Tomos case performance?Re: J Dubbs J Dubbs 01/02/20 06:31PM
  Re: Diy reeds cut directly into Tomos case performance?Re: Daniel '' Daniel '' 01/02/20 08:06PM
  Re: Diy reeds cut directly into Tomos case performance?Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 01/02/20 10:45PM
  Re: Diy reeds cut directly into Tomos case performance?Re: P D P D 01/03/20 09:09AM
  Re: Diy reeds cut directly into Tomos case performance?Re: . . . . 01/03/20 10:50AM
  Re: Diy reeds cut directly into Tomos case performance?Re: J Dubbs J Dubbs 01/03/20 01:15PM
  Re: Diy reeds cut directly into Tomos case performance?Re: . . . . 01/03/20 01:37PM
  Re: Diy reeds cut directly into Tomos case performance?Re: Daniel '' Daniel '' 01/03/20 02:29PM
  Re: Diy reeds cut directly into Tomos case performance?Re: J Dubbs J Dubbs 01/03/20 02:46PM
  Re: Diy reeds cut directly into Tomos case performance?Re: * * * * 01/03/20 03:02PM
  Re: Diy reeds cut directly into Tomos case performance?Re: niklaus _ niklaus _ 01/04/20 03:11AM
  Re: Diy reeds cut directly into Tomos case performance?Re: Totally normal JBOT Totally normal JBOT 01/04/20 12:18PM
  Re: Diy reeds cut directly into Tomos case performance?Re: Daniel '' Daniel '' 01/04/20 12:22PM
  Re: Diy reeds cut directly into Tomos case performance?Re: . . . . 01/05/20 09:32AM
  Re: Diy reeds cut directly into Tomos case performance?Re: J Dubbs J Dubbs 01/05/20 05:58PM
